Has anyone ever had a regular 10" blade bored for your Kapex? I have a lot of unused 10" blades I was think of getting them bored. I know the Kapex blades are slightly bigger, but the saw has a depth adjustment screw to accommodate this. So before I spend the money to get them bored, and not to mention if it doesn't work I've wasted 100's of dollars in blades. Opinions?
I'll be dammed if I drop 120 per blade from Festie.
Sure do. I have about 6 or 7.
ranging from 24t, 36, 42, 60t also aluminum blade and fiber cement. Including festies I think 100 and 120t
Aluminum blade works really well on Aluminum tubes etc of course and ipe set speed at 2-3speed
I think I paid about $9 bucks for the hole.
You loose about an 1/8 in depth and find it works smoother by adding 3/4 ply to fence as backing.
Pick your best blades the ones that are worth re-sharpening.
