1/4" over popcorn
64K views 17 replies 11 participants last post by  Sir Mixalot
I have a guy that wants me to put 1/4 drywall over (under) a pop corned ceiling. I don't think its a good idea, thinking it will be uneven at best. I do not do much drywall, so I've never done that. I'm thinking the popcorn should be scraped off first.
Anyone have any experience with doing this? Anyone have any thoughts?
I know some one has an opinion, care to share it?
#9 ·
Absolutely in this state (WA) you are required to know enough to know that there are things that may need to be tested before you start a job. If you go and scrape that stuff and it has asbestos in it, you're up $41t creek.:eek:
It also makes a huge mess.
#3 ·
If you put 1/4" on a ceiling, you have to bond it to what is there already, or it WILL sag, To get a decent bond, you may have to take the popcorn off (depends on how well it's stuck on). Even if you leave it on and can get a good bond, you're going to be going over an uneven surface. That's a lot of time and money to get a crappy job.
#8 ·
1/2
' or 5/8
' Scraping can get real messy and does damage surface, not to mention the chitty tape job covered up by popcorn. Lower light fixtures, mark ceiling joists (studs) and put a new layer. If I have a choice I will take the overlay over the scrape. 48 sf' of new rock at say 11 to 14 bucks a sheet..... cheaper and better to go with new rock
#11 ·
i do a lot of popcorn removal its really pretty easy. take a garden pump up sprayer, probably 2 gal, fill it with water add 1/2cup fabric softener. spray the ceiling let set for about 15 minutes, then spray again. remember you just want it damp, not wet. Then scrap with a 6 inch knife, no bigger because if you look down the edge of a big knife you will see it has a curve, that will make the corners dig in and make repairs more and harder. Spray occasionally as you work. With this method you will get very little dust. Hope this helps
