Status
Not open for further replies.
1 - 4 of 4 Posts
Hi Guys,
I'm running a 3" stack for a toilet from a second floor bedroom down into a basement utility room. Its a remodeling project adding a bathroom. Ran into a situation for which I can use some advice.
Currently have horizontal 1 1/2" drain pipe going into the end (with a reducer) of a horizontal 3" stack that then goes out to the septic. The 1 1/2" is a drain for a couple of sinks.
I need to tie into the end of that 3" with my new 3" from upstairs. Again this is a horizontal portion of the run, sloped appropriately. That means displacing the 1 1/2" drain pipe.
If I do the above, I'm going to have the 1 1/2" and my new 3" running parallel to each other. I need to tie that 1 1/2" back into the 3". Can I use a 3" wye with a 45 coming off the side. Add another 45 to the existing 45 to turn the wye into a 90 where the 3" and 1 1/2" run next to each other?
Not sure what code is or the proper way to make this connection. As you may have surmised I'm a homeowner. I have licensed plumbers coming Monday to do the bathroom rough-in and I agreed to have the stack ready for them.
Capra Aegagrus
Remodeler
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer that you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractors to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
1 - 4 of 4 Posts
Status
