I'm installing a large block wall for a customer, and while we had the backhoe on site he asked us to dig out along a section of his concrete foundation that is failing.
As you can see from the photo, the exterior wall shows severe scaling, in some places up to several inches deep, although it has not yet broken through completely. I've cleaned off most of the loose scale (as much as I dare), and pressure washed it down to a relatively solid base. But I'm unsure how to repair it. Possibilities I've discussed with the owner:
The house was built in 1973 in coastal Maine, and is subject to freeze/thaw cycles and salty air. The trench will be filled with sand/gravel once the repairs are complete. Concrete isn't my forte, so any suggestions will be appreciated.
- Build a form a couple of inches out from the current surface, and pour new concrete up against the old. But I'm afraid it won't adhere well.
- Mix up some concrete resurfacer such as Quickcrete Concrete Patcher and hand-trowel it on in layers, building it up to its original thickness. But again, not sure it will adhere well.
