1 - 20 of 25 Posts
No worries dude!
Seriously...there's little worry here!
Technically, typical Interior resins are a little harder. Exterior binder-resins are usually slightly more "flexible".
It'll probably wear just fine. Slight odds of it cracking earlier, depending on the wood' movement.
Faron
Discussion starter · #7 ·
Faron
Thanks, I was thinking the same thing but wasn't quite sure.
Jeff
I have been told by Paint Reps that if you apply interior coatings on an exterior they will fail.
If you coat over them with an exterior product they will still fail. what will happen first is the exterior top coat will become chalky within a year and then you will have the peeling and blistering.
I have not tried it to see if my Rep is correct but if it is your house I say let it go and see what happens.
Exterior and Interior paints are manufactured to hold up to the elements they are meant to be applied in. An interior paint used as a first coat on an exterior application with an exterior paint applied over that is just trouble. It will not last and you will have bubbling paint because the interior coating will not hold up. Even with a top coat of exterior on it.
I know sometimes like SW can get confusing when using Super Paint because they make both Interior and Exterior for the same name. Thats why i always check, check and recheck all the labels. We actually had new people at the paint stores shoot an exterior color for an interior paint and vica versa.
This is what the manufacturer said:
You may apply an exterior paint over the existing interior paint. This will seal the coating and prevent any future problems.
Jeff
Not meant to burn you, but in my opinion that Rep may be mixing his meds...
First thing is to turn in your Painters Card.... just kidding. 6 years ago I had a guy do the same thing to his porch columns, we went over it with oil-based CoverStain primer and topcoated it with exterior. Other than the regular exterior grime they've held up through the Nebraska weather extremes. Might want to give it a shot.
Discussion starter · #16 · (Edited)
Wolfgang, very interesting.
Do you think it was the oil based that was the key or just the primer/topcoat application by itself?
I'm also curious if the interior coat was also oil?
Jeff
Last year I was working on a job where the painters painted the exterior of the house we were renovating with interior paint. They couldn't speak or understand English so they didn't understand when we tried to tell them. The GC didn't make them redo it so the interior paint stayed on. I went by the house a couple weeks ago and the paint still looks good.
1 - 20 of 25 Posts
