I have done several epoxy floors but I have never been happy when using non-slip additives.
I am looking at a residential garage, customer wants epoxy floor with color flakes added. They keep their car in the garage and wash their car in the garage.
Generally when I do epoxy I use Armorseal 1000 (solvent base) A and B components. Two coats with flakes broadcast over the wet second coat. I then seal over the flakes with clear Rexthane sealer - two coats.
Reason for the sealer is to lock down the flakes so hot tires don't lift them and for UV protection when overhead doors are open.
My concerns are the sealer will make for a slick floor when they wash their car in the garage. My experiences with adding slip resistance (shark grip) to the sealer is the finished result is not to my liking, either the floor turns out too dull and cloudy and the shark grip shows lap marks where the roller overlaps, usually both.
Does anyone have experience adding shark grip to the second coat of epoxy and sealing over it? (this is what SW product hotline is suggesting)
Gladly open to other suggestions.
