2 story covered deck. More like a porch.
1st floor is an EPDM, because it covers a basement.
I didn't use PT, because I'll do just about anything before I install a 20' PT 6x6. :blink: Nasty $#!T.
I don't have to worry about the top of the post, because it has a roof with overhang.
My original plan was to wrap the posts with Tyvex, and trim them out. I'll put spacers in, to allow any water that might soak through to drain.
There will also be sheet metal flashing at the bottom, where the posts penetrate the basement roof.
And I designed a sort of elaborate flashing and counter-flashing set-up for the second story, where the 4x12's are attached.
But a contractor friend of mine suggested I just paint them. He's concerned about water getting trapped behind the trim, and concealing rot.
I'd be worried about the 4x12 to 6x6 connection, with only paint. As soon as water gets in the crack, and starts seeping into the end grain......
