Here are the results of shooting a 2" x 4" at both materials.
If a broken window is a house failing, then I guess you got me. I could counter that you may have one instance in a neighborhood of 100 houses with windows covered where a 2x4 hits directly enough to cause that result. I would counter that with each homeowner saving $50by using osb, which is a savings of $5000. I can buy and install a bunch of windows for 5k.The video did just show you a house failing. I guess you are o.k with flying debris coming thru your walls.
I'm not advocating titanium walls,how about just something like solid wood or at the least plywood. If you are not able to recognize / accept this video for what it is,so be it.
That small hole in the osb does not represent the window getting taken out. Like I said, I agree that the plywood is better for boarding up windows. But you will not have a bunch of 2x4 type objects spearheading at multiple areas of a house like they show in that video. You can think what you want, but even if I was building in Florida, I am sure I would continue to recommend osb.I wasn't talking windows,I was talking walls. Plastic siding covering osb sheating is a recipe for disaster. Wind blown debris is coming right thru. At least with plywood sheating you have a fighting chance it will get stopped.
Plus the windows are only the tip of the iceberg. It is a proven fact once windows are knocked out in high winds,the chances of keeping the roof on are greatly diminished.
Kind of not true, but kind of is. A 2X4 hole could be the straw that breaks the camel's back in a lot of situations. The push of a hurricane is really intense but when you throw in negative pressure it can be a disaster. It pulls a chunk from that hole and then more because the walls ade sheated with OSB and everything is getting wet for hours and becoming compromised.Fred, gotta say I'm with Warren on this one. Sure, plywood will do better than OSB with a direct point load shot, but in reality the odds of that happening as depicted in the video are pretty low. The odds of it happening to multiple windows are lower yet.
Common sense says that you don't spend $2-3K to protect against the chance of one or two busted windows. And as for wall sheathing, a 2x4 hole in the wall isn't going to do diddly in terms of blowing the roof off.
A very generalized opinion, but really without merit. Show me some data that shows any house ever failing because they used osb vs plywood. If we are gonna use your rationale, lets just start making some sheathing out of 1/2" titanium, and use that.
In Tampa, we haven't had a direct hurricane hit in 100 years, far from a prone area. In fact many live here because of just that - they almost always seem to skirt around us somehow. Almost always :whistling.I certainly hear what your saying,however,if you live in an area prone to hurricanes,would it not be prudent to have material cut to size and numbered for each opening needing protection stored in attic,garage,crawl space or some similar location for each time there is a threat ? It seems anything short of that is irresponsible.
I don't want to call you ignorant, but this statement is. At equal thickness OSB has almost twice the shear as plywood. That's why they make engineered joists out of it. Now it's not without it's shortcomings but in construction a little education can go a long way when it comes to choosing the correct materials. Both in terms of build quality and cost savings.Agreed,but you have to test some way. The point they are showing is the inferiority of OSB,which is pretty much the material used the most for walls,floors and roof sheating. Why ? Because it is cheap.
as a siding installer the nail holding ability of ply wood in the nominal 1/2'' thickness is slightly better in the plywood...I know hit studs etc...
Exactly. :thumbsup:
I trust my engineers. I'm never going to use more than the numbers require. Why would I do that?
Mike.
_______________
[emoji631] [emoji631]
Actually not. Buildings don't fail from differences in sheathing, they fail due to foundation movement, rot due to roof maintenance, and sill / lower part of stud rot. There can be other major rot issues due to plumbing leaks or general envelope issues.Why,because codes represent the bare minimum allowed. And that truly is marginal.
Because I put steel siding on I rarely worry about studs unless it does not have some kind of sheeting under it. All of mine gets screwed on any more.not all siding needs to be
