Relocate basement plumbing
13K views 20 replies 13 participants last post by  Double-A
Starting a basement finish job and need to relocate the bathroom rough-in approximately 16 feet. Should I jack-hammer the trench or use a conrete saw.
#8 ·
I would use a plumber...........................................
They come in handy to block the debris from the jack hammering:laughing::w00t::laughing:
Don't quit your day job Rory!:no:
Use a jackhammer,using a cutting tool only messes up the furnace,waterheater, basically dust all over, also when you use a saw you get a straight line, looks good but when you pour crete in ,it wont hold as good ,with a jackhammer you get rough edges for the new crete to hang on to, after you crete it up,pour a thin layer of jiffset over it to smooth out, sounds dump to have rough edge but i have seen many crete seperating with a straigh edge
Something small like that, we use a crappy circular saw with diamond blade, pail of water, and a shop vac. Then we bust it up with a Brute. Bigger runs we'll use our walk behind saw and garden hose attachment. But our work usually gets lino, tile or carpet over it, and we never see a joint. Never left it bare, so I couldn't say what's better.
#7 ·
I learned a good trick from my plumber a number of years ago. He will use his jackhammer to make a hole large enough for a square edge shovel, excavates under where he wants to go and uses a sledgehammer to break the concrete. Keep excavating where you are heading and you've got yourself a nice trench!! A lot quicker than using a jackhammer for the entire thing and a lot less dusty than cutting.
#20 ·
Luckily we have a company here that does it too, but to the tune of $1500...but, they do dig the hole, and haul away most of the dirt leaving just enough for backfill...kinda hard to get cheap HO's to go for that kinda change on top of our normal charge, but when the interior is finished i have no choice but to bid it that way since like you said there is minimal mess...otherwise i just get the electric quickie and do it the hard somewhat messy way:censored:
#21 ·
Moon, if you're not a DIY, then please post and introduction and tell us about yourself and your business. If you're a DIY and this is your home, please respect our rules and post your question on DIYChatRoom.com.
Thanks
