Looking for some help with an existing concrete 'deck' more of a balcony I guess.
5.5'' thick slab of concrete on the back of a house one story up.
Its solid and sloped away from the house, seems to have good drainage.
Wish I had a better pic but you get the idea.
I want to lay a pressure treated/ipe/composite frame of 2x4's over the slab.
The frame would be fastened to the slab and then lay an ipe deck over this.
Is there a recommend air gap to prevent rot of the deck and frame ?
Can I lay the 2x4'' on their side so I have 1.5'' gap ? ( i have limited height I can add)
Would plastic spacers to lift the 2x4's off the slab be enough ?
Should I not bother at all lol ?
