thought i read on john bridge that if you use a liquid membrane like redguard over hardibacker you must not use poly or felt behind the backerboard....saying that could trap moisture.
so if densGuard has a build in moisture barrier would that mean i can use redguard?
i called the tech line and the dude said you dont need the redguard but its ok to use it. wouldnt the seam leak without redguard? and anyone think redguard could trap moisture when used on densGuard. not sure where the moisture would get in maybe from behind where the two panels meet.
also im trying to decide what order to do this shower what would you guys recommend?
should i install densGuard and tile wall before even doing the top layer of deck mud on the shower pan? seen a couple pics on the other forum of people doing it that way. its only a 3x3 shower. thanks for any advice
