hey guys,
i've framed several times using I joists for flooring, but never for roofing, we are going to be building a work shop addition and the span is 27' and the plans call for I joists but don't give any other details on blocking, overhang, birdsmouth etc. I have a few questions. how do you attach the i joists when you are taking a shed roof(with ijoists) and fastening it to a another roof that is a 12/12 pitch? do you just put a 2x ledger and fasten that to the 12 on roof and do they sell hangers for all types of pitches? we are taking a 2.5 on 12 shed roof and going to a 12 on main roof for part of the shed, the rest of the shed roof butts to a gable end wall of the existing house. I'm sure that on this area we just bolt a ledger to the gable end wall and use I joist hangers with web stiffeners.
ok, on the other end, what's the best way to fasten a soffit and fascia boards to the end/bottom of the i joist as it's overhanging the outside wall?
i'm starting to wonder if it would be faster to frame this whole thing with LVLs for rafters and skip some of the expensive hangers and web stiffeners that are required for i joist roof framing.
I know the LVLs would be costly but saving labor is a good thing. what are your thoughts? how much longer does it take to frame a roof with i joists?
since this is my first time using these for a roof, i'm open to all suggestions you guys who frame with these all the time have.
Thanks again
Dan
NJ
Thanks again
Dan
NJ
