21 - 40 of 53 Posts
The rows that you see in the picture it's called a "header course".They usually did this when they built brick walls 1'6" thick so they laid on brick on the outside, to have the narrowest side of it to be seen longways, and the next brick, or the next row, or every so many courses have brick laid so only the end seen "laid flat" so they called that pattern Stretcher and a Header.
If a brick end was laid in a vertical position they called that Stretcher and Rowlock.
This is good stuff. I've never known anything other than brick veneer and could never fathom the concept of a "brick wall" that wasn't made of something else.
:thumbsup:
It's not a pissing match, it's information.
One can be informative without being contentious, as others repying have demonstrated.
A reply that begins with "you're wrong, I'm right", is contentious and always someone wanting to start a pissing match.
I declined.
like telling someone that a joist is called a joist not a stud
No, like me saying "we call that a rowlock wall", and Cliff Cliven suddenly feels the need to name every part in a brick wall.
Now you want to start a pissing match, and again I will decline.
Not trying to start anything, just trying to relate information to someone who is another trade and who may not be familiar with masonry terms. If I called a stud a joist or vice versa I would want to be corrected. Information about the different trades is one of the best things about this forum
I've always heard it called a tie course. Different area I guess.
They are used to tie the two walls together.
I know this was covered above, but there were some other things mentioned, so I thought I would mention it.
It is a tie course...a particular type of tie course called a header course
:thumbsup:I know that. You inform, not "school". I'm interested in learning too.
I see a common bond, but I'm pretty darned sure its a header course tied back to an inner wythe.
And I (and some others) call that type of wall a rowlock wall.
I find it strange that the OP would think the Header course were "illegal", or against building code when in fact buildings built with out sufficient actual header brick that weren't Hammer cut bats to speed production/use the waste bats to tie each wythe to each other were against public ordinance.
Maybe a lazy mason didn't want to mach the existing and lied? Hillary?
Usually 2 or 3 % of the face units would have to be headers tie the wythes together. as has been learned by the few hundreds of years of experience with Dutch and English bricklaying. otherwise the outer wythes would peal off in entire layers, many times killing passer-bys.
Then as now uninsurable buildings were nearly impossible to resell or secure a mortgage on.
Many towns in America their veneered 80-120 year old brick buildings wall ties have rusted away leaving the veneer ready to peel off at the next large wind or minor earthquake.
In general, I find that people were just as smart as we are if not smarter, as they had far less money and technology to do what they accomplished. I think today's Americans are far more superstitious then ones from the late 1800s, and in general think and act more illogically.
Reactions: Fundi
They aren't illegal anywhere. Your area may require MORE bonding than a header course but they certainly aren't illegal. Like I and others said before, it's not a building style that is commonly done anymore particularly in seismic areas that require rebar, but there is absolutely nothing illegal about it
21 - 40 of 53 Posts
