Hi Everyone,
New to the forum, but already learning a lot.
Im doing a full gut rehab, that has essentially snowballed into becoming a new construction home.
Plumbers started over the weekend when I was not on site and drilled through the 2x8 joists. Joists are doubled up per SE and the span is about 14'. Do you think this is going to fly, or should it be headed off or reinforced in some way? Plumbers told me I'm crazy for even thinking its going to be an issue at inspection.
What do you think?
Pics and rough sketch attached.
What do you think?
