1 - 20 of 21 Posts
skipmo
I'm building a spec home and got a buyer during construction. The home interior is taped, floated and textured.
The new owner has asked me to research eliminating the curb on the master bath shower. The concrete is not depressed; I intended to install the curb, then have the tile setter slope the floor to the drain in the center of the shower. The shower is 42" deep by 80" wide and has 2 heads.
A while back I stayed at a new Marriott hotel and the only room available was handicapped. The restroom had the shower and toilet in one room about 8' by 6'. No shower curtain or device to prevent the water from spraying anywhere in the room. What got my attention was the fact that the slope was almost non-existent; very slight. There was no obvious mud bed for the floor tile.
Here's my question: Is there some new product, like a very thin "painted or sprayed on" product that allows one to eliminate the typical mud bed and cleavage membrane?
I'm not afraid to admit I just learned something.
I've never seen a shower base that thin. We've done several 0 entry showers, but we always lowered the floor joists and built up a base. The ARC system looks really good. I think it will work great for our next bathroom with 0 entry. Have one to start on 4-15 and bidding another right now.
Thank you.
I can't take full credit, another member on here, TNTSERVICES, has been using them and brought them to my attention. I have one on order that I should be installing in the next couple weeks. There's some trickyness with them, but they seem to be a very unique solution to a difficult/time consuming problem.
A number of members on here have installed them and seem to have very positive feedback. I will say though their technical documentation is a little lacking when it comes to the waterproofing membrane (which i hear they are changing).
Sound like your bath is built on a slab not over framing. The ARC is for framed applications. Also, the ARC system has a slope of 1/8" per foot. The guideline is 1/4" per foot. You might want to add cement/thinset to the perimeter of the area.
Assuming you have a centered drain, just change the drain to a linear drain. Yes, you have to chip out the cement. You could shorten the drained area if you have bench seats on either end.
With a slab, you can use a liquid waterproofer on the concrete. Be sure to extend out past the shower floor by several feet or do the whole floor.
It looks like the OP might be a one-and-done.
Serious? ;) I use "Remodel" in my name as a joke.....maybe I should change it to "General Contractor"? It appears general contractors don't know anything...nor ever have any subs/employees. Sounds like a good gig, working about as often as I remodel something.....
It can be installed over concrete.
" You have a couple of options, though as always, we prefer installations that provide zero-threshold entry into the shower. You can remove concrete to a depth of 1″ in the area where the Tuff Form will go. We do this with a special concrete-cutting saw and blade, first cutting along an outline of the Tuff Form’s installed position, then making scoring cuts about 1" apart inside the perimeter cuts. We remove the remaining waste with an electric hammer drill and chisel. Use thinset mortar to bond the Tuff Form into the recess. Alternatively, you can install the Tuff Form on top of the concrete and build up the surrounding floor to end up with a level entry into the shower."
For what the Tuff form costs, why would you use it after you just prepped the floor by surfacing a pitch to the drain anyway?
Since the width of a shower is shorter than it's length(usually), a linear drain should go lengthwise in the opening. Assuming a 36x 60 area, the pitch on half the 36" width is 3/8" (1.5x1/4"). On the long edge, it's half 60" x 1/4" or 5/8". So you save a 1/4" of pitch which can be important.
Another way to save height and match slopes is to use thin 2x2 in the shower and set thicker tile in medium bed thinset outside the shower.
I wasn't recommending it, just saying that it could be used on concrete.
But off the top of my head I would say that concrete cracks. Waterproofing won't hold a Crack together. The pan won't transfer the crack. The tuff form installation will continuing to be watertight.
I have no idea what you're talking about. I was saying that he posted once on CT and never came back.
And most of those liars use "General Contractor" as their trade...because they have no trade. They cannot talk about anything other than to lie and do their one post to get their "how to/how do I..." question answered.
I suppose. Concrete cracks but does it crack continuously? Most liquid waterproofers supply some degree of movement accommodation. And some sheet membranes as well.
Where the Tuff Form would be useful on a slab would be if the slab had known problems. It would be independent of the slab. But I would think a pro would take care of the problem slab in other ways before committing to tile.
I don't disagree, just answering the question.
EDIT: I have seen cracks in my basement slab and garage continue to get larger over the years. My garage hasn't seen a car in at least a decade. I don't know how you would address that after the fact. I've just never been a fan of using the existing concrete as a base. I want some separation.
1 - 20 of 21 Posts
