1 - 8 of 8 Posts
newguy1
Hi guys,
I recently took a job where I will have to rent a ride-on trencher, a small tractor, and a stump grinder. I do not use these very often so I am just going to rent them. I am deciding between going with Sunbelt or United. The prices are fairly similar so I am trying to figure out which is better overall.
I was wondering if you would be able to talk about any experiences you have had with Sunbelt and/or United and which you think is better
Looking forward to hearing your responses!
Sunbelt has everything painted green, United does not, that pretty much explains the difference between the two.
I've rented from both, don't really have a preference between them.
I do however have a preference to rent from my local guys that have one or two locations. I know the guys, I know where the profit from the rentals goes....It stays here in my area.
I don't have anything against the Nationwide companies, I just prefer to support what's left of the "Good ole' Boys."
Obviously not every local has the options we have here.....
You have posted essentially the same question in 3 separate threads, you really should keep it all together in one thread. It helps keep things linear, and easier to follow.
I have an account with sunbelt, they treat you good if you become a regular, each sales guy can see how much money you've spent with them instantly right on the computer, they will treat you differently if you don't spend much.
1 - 8 of 8 Posts
