1 - 20 of 22 Posts
nailspitter
· Contractor
Need help / advise. Did a basement remodel job and used DAP Alex Brillant White Caulk along the Chair Rail, Baseboard and Crown moldings where they meet the walls. Finished it about 6 mounths ago. Got a call from the HO. All the caulking turned yellow.... Any thoughts of why and Advise?
Painters caulk yellows. That's why you usually caulk first and then paint. I still want to expiriment with the Ben Moore color match stuff to see how is holds up. I use DAP Dynaflex and it will yellow in a week or so if not painted.
As was mentioned. You need to paint any latex caulk.
They may not yellow but they will collect dirt.
Not really anymore than paint would...nothing like white silicone or polyurethane.
Polyseamseal in particular stays very clean, almost self washing if you will.
I am unfamiliar with Polyseamseal but I've used Phenoseal. Phenoseal will gather dirt and you won't be able to wash it off just like latex caulk. With paint you can wash it and it will come clean.
All the trim and the wainscoating is PVC. I dont believe paint will stick to pvc? DAP states "Brilliant White Dries Clear Wont Yellow" That's why it was chosen. Any suggestions on how to remove it?
Wipe with spirits and re caulk
I think this has been debated not too long ago in another thread. I have been using phenoseal for as long as I can remember , It's a latex caulk with adhesive and doesn't shrink nearly as much as other latex's such as Dap . You get what you pay for .
I always paint PVC it actually holds up better than on wood. And why are they stating brilliant white when it dries clear? I don't care if it comes out black if it's supposed to be clear when dry. Stay away from Dap when possible. I don't see how you're gonna repair this without painting.
1 - 20 of 22 Posts
