41 - 49 of 49 Posts
Discussion starter · #41 ·
Say you had a rise of 300mm for the dormer, and it had a run from ridge to plate (level with the plate line) of 600mm. Your formula would look like: 300/600 = X/250... Which you would cross multiply. Ends up looking like X=(300x250)/600. So your plumb cut would be marked on X, or 125 in this case.
Anyway, hopefully that didn't come out too confusing, that's just how I was taught. Knowing how a framing square works is always useful.
HI again Shane,
thank you very much for the example,just a question,do you measure the run from the center of the ridge to the outside of the plate?maybe is a stupid question..but is worth ask!do you work both with metric and imperial system?have you ever seen a metric framing square in canada?i found only a metric speed square,but learn how to use a framing square would be,like you and many other suggested,very helpful!thanks for the reply!
HI again Shane,
Since you are building in place, I would just go from outside of plate to face of ridge. That way there is no extra shortenings involved, just a straight measurement. In Canada we use both systems, since we export dimensional lumber to the states, it all comes in imperial. I mainly work in metric, as most commercial work has switched over to it. I have a metric framing square yes, in fact an old foreman of mine apprenticed with the guy who invented them (supposedly).
I'll admit, math isn't my strong suit, but you confused the heck outta me. lol
Haha sorry Jon, I have a bit of a math brain. That's how I was taught during my school portion of my apprenticeship. Actual rise times framing square run, then divided by actual run gives you the framing square rise. On a small enough scale, that shouldn't matter as you could fit it on a square anyway. But proportioning it down let's you fit those same dimensions on the blades of the square without changing the angle.
Discussion starter · #45 ·
thanks Shane for the detailed explanation,just one more question,what´s the brand of your metric framing square?i found a Chapell metric framing square but is extremely expensive,do you know where i can find one?thanks!
Mine is just a run of the mill Stanley. It was cheap and available at the time. When it needs replacing I'll be buying a Frederickson metric framing square.
Discussion starter · #47 ·
hi again Shane,
i searched online for this Frederickson framing square but i can´t find any seller,do you have any idea where i can get one from?thanks for the help!by the way this Frederickson comes also with a booklet in metric with different roof tables..very useful..
Discussion starter · #48 ·
Just for talking guys i´m dividing myself between this mirror that i finished today,some furniture details work and the playhouse..if there is someone from Canada or US anyway,that knows where i could find the Fredrickson metric square,that Shane as mentioned,please let me know,it would be a nice thing to have for me..unfortunately i can´t find anyone online that seems to sell this metric framing square..
41 - 49 of 49 Posts
