Can someone recommend the best method for attaching vinyl windows on new construction. I have used deck screws and they work good but the heads are not flat and if you overdrive them it can split the flange. I have also used roofing nails because they are flat. Only problem with roofing nails is if you are a one man show you cannot unscrew and make adjustments if needed. Just curious if anyone else has a better suggestion.
