I have a question I would like to get your opinion on? I have a kitchen that has pre finished stained trim. It is a light golden oak color. On a few walls there is a crack between the baseboard and the walls? What do you guys do in this case? Do you tape the base, caulk and then paint the walls? Do you do nothing? Do you use a clear caulk? Do you use a tinted caulk? Thanks
