what works for most finish carpenters up here in the Northwest is, get a rubbermaid cart. whether the large one or the smaller compact one, and apply sides and doors on it. :thumbsup:that way you can lock it up each day.
as for myself, i have both. loading the bigger one is tough by yourself, but i usually work with others so i like taking the bigger one which stores more tools in the lower compartment. i do a lot of doors and hardware, so i like the smaller one when i am doing that.
the awesome thing about using these carts is, you can personalize them and make the your own. for my smaller one, i made a two drawer box to fit on top of it, which i use pins that fit into a deep hole that i use a magnet to get them out for locking it. works great. at the moment, i am using the larger one which i took the box off the smaller one and am using on the big one at the moment. one other thing i did, was change with wheels on the larger one. one thing i recommend is taking off the stock wheels and putting on soft solid rubber wheels. not neumatic. i put nice 4" soft rubber wheels that will roll over cords and other things easier than the stock wheels. i will try and take some pics to show you guys. once you have one of these carts and customize it, you will have it for many many years. i have had mine for almost 10 years. still going strong.:thumbsup:
