Have any of you all found a good and fast tool to remove the outside window stops without messing them up and making a big mess??
Agreed.I generally find pulling them to be faster and easier.
Maybe it's a terminology thing, or the older windows in your area are constructed a bit differently from around here.Not sure what you all mean by pulling them? Generally on a replacement window you cant just pull them off since they go in behind the outside casing. We don't always cap the window either so we cant mess the stop up any.
That's a detail I don't recall ever encountering, but since it's in that drawing, I guess they do exist. :laughing:I am talking about the stop on the very outside that is on the inside of the casing.
You're right GRB.... we see it run behind the brickmold here sometimes as well. When that happens, we score it several times with a knife, and then snap it off. We then set the window, foam with OSI-TEQ low expansion foam and then cap the brickmold and into the receiver channel on the window and caulk everything in.It's referred to as a blind stop around here & is normally overlaid with the brickmold or other exterior trim. It runs behind the trim & is often a PITA to remove.
If I understand the RRP rules right even doing the window replacement from the outside does not do away with the cleaning verifiction and documentation.We are in Wellman, IA which is in the Eastern part of the state. What kind of blade do you use with that multitool?? Not sure what you all mean by pulling them? Generally on a replacement window you cant just pull them off since they go in behind the outside casing. We don't always cap the window either so we cant mess the stop up any.
The main reason we are looking into this is, complying with the lead laws should be easier since the window would be replaced from the outside and we would not have to do the cleaning verification documentation etc. So far we have been replacing our windows from the inside.
I would agree with this method being the easiest, and most popular of our methods.Score and then Chisel works for us.
Then a full metal cap to finish it off.
Sam i believe the reason guys are pulling the outside stops is to get the old sash out,if your going to leave the sides in why pull the top stop?..i don't think i'm understandingSometimes I have just cut the top stop off then take the replacement slide it behind the stop on the left or right side push it in as far as if will go. Then push the other side in and center it that is of course if you have the room. I do think that cutting it out sometimes makes it harder to seal up correctly if its not being wrapped in metal. As far as the Lead remediation goes you have to plastic of the window from the inside. Remove existing window hepa vac the opening install new window. Take down plastic inside and hepa vac the surrounding area. It takes just as long if not longer to do all the plastic and the vacuuming then it does to actually install the window.
