building a waterproof balcony above a deck.
12K views 8 replies 8 participants last post by  Greg
wondering the best way to to build a wood balcony (8x10) that doesn't allow water to drip onto the deck below. is the way really to build a sloped/membraned roof and then float a deck on top (reversing the slope) without compromising the membrane?
#8 ·
Paillion
Can you take a clue from the house as to design. Is there some motif? Is it a freestanding post and beam 'pavillion like structure over a deck already built?
Overhang a flat membrane roof out past the decks perimeter by some distance, no rain
And as you say float it.
My question is. What's a good way to put a deck on a flat roof I am loading my decks over to the outside walls. A lot of times too, you only have 6" from the sill of the door to the top of the flat roof which means to meet the sill you can only use 2x4. You end up having a 2x4 beam in the middle. Anyway it seems to work thou little bouncy. And where it meets the roof it sits on a styrafoam pad...
Is this valid?
Building a deck above a deck
Building a deck above a deck.
I have build this same set up here in North Vancouver.
We used 4" x 10" floor joist on 30" centers tops with 2"x6" V-Grove Spruce for the flooring (amazing look from the bottom deck looing up). Then I cut custom sleepers to a single drain location on my master deck. I installed the sleepers and topped them with 5/8" plywood and then a double layer of torch on. One giant shower pan...
On top of the torch on is cement pavers that sit on rubber pads that I shimmed with scraps of the torch on and roofing shingles.
Looks great.
#9 ·
We have tried several methods over the years and 9 times out of 10 we will use EPDM and then add a soffit of some kind. If you do a search here you might find a detailed pdf to show you how. It is faily easy, quick and inexpensive. I like the fact that it completely isolates the framing from moisture, as some systems can always hold moisture in close proximity to joists.
