I've only done face frame cabinets to walls, so scribing is easy. I've never done any frameless cabinet wall fitting. What do you guys like as a method for getting a tight fit against a wall with frameless cabinets? Thanks, Nick.
Yep. I like the fact that it is l shaped. Easy to install and scribe. Thanks. I suppose it could be as thin as needed as long as the wall isn't way out.Gus Dering said:You really need a "filler" at the walls to build in some play.
1 1/2" is our standard. The cabinet has an unfinished end and the filler is shaped in an L with a piece of 3/4 on the side of the cabinet as a mounting surface for the filler that is flush with the door. So there is really only 3/4" available for scribe. Make sense?
:whistlingLEVELBEST said:. Scribe the filler to the wall, shim the back of the cabinet out accordingly, screw it and do it.
Same here Leo. I extend mine 1/2" though. I'll make the stile 2" wide so everything inside stays consistent. That 1/2" around here seems necessary with the way the walls lean and sheetrock tapers.Leo G said:Yes the exposed end has a 1/4 or larger scribe. Apparently I am old school and damn proud to be in the club. If you have a flat (slab) end panel nothing will look better than using this method. It also gives full support to the cabinet so you can level and plum the cabinet a screw it to the wall using minimal shims. I like the nice clean look and I get paid for the time. And as long as it isn't a radical curve in the wall, as long as the cabinet is touching the wall at all spots your eye is fooled to thinking it is a straight line.
I beg to differ. We set the fillers back on the economy jobs because it is easy. Commercial jobs, garage cabinets, some laundry rooms, or a cut throat blow and go job are all places to save a buck.For Frameless cabinets next to a wall - you need a filler piece to allow the door to open without "knocking" into the adjacent wall. Filler really should be a minimum of 3/4" wide. This applies to any placement where the adjacent cabinet/wall is deeper. The filler should be set flush with the cabinet face frame not the door. The filler can be scribed on site to the wall.
For Framed cabinets - I usually design with extended stiles that can be scribed on site. The extended stiles are, like the other poster mentioned, like "wings" of extra material the cabinet was made with during construction. They can be ordered as thin as 1/4 " up to 12", with 3" and under being the norm. It's a nice option to avoid seams from filler pieces as the extended stile is one continuous piece. Almost all the medium to high end cabinet manufacturers have this option during the order process.
