Spent Map Gas And Propane Bottles - Page 3 - Hazardous Materials - Contractor Talk
Old 05-12-2015, 09:33 PM   #41
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,078
Re: Spent Map Gas And Propane Bottles
They showed how to fully empty propane tanks on hillbilly blood. Of course these were the kind you use on fork lifts. They said they're never really fully empty. Idk if it's the same for these.
illbuildit.dd is offline
Old 05-12-2015, 11:09 PM   #42
Texas Wax's Avatar
Rewards Points: 2,288
Originally Posted by Inner10 View Post
Unless your empty propane tank has a mixture of air and propane in it.
I realize that's a rhetorical come back.....
Equalization of pressure internally to outside air pressure, there will still be no or very little air in the tank. And certainly no where near the explosive limit (proper mixture of air and flammable gas to ignite).
Texas Wax is offline
Old 05-12-2015, 11:40 PM   #43
GC/carpenter
Calidecks's Avatar
Rewards Points: 158
I once put a saw kerf through a gas pipe. Scared the living bejesus out of me. At first from the sound I thought it was a water pipe. In hindsight I'm glad it was gas. At least I didn't have any water damage.
Calidecks is offline
Old 05-13-2015, 05:27 AM   #44
Box Builder
Morning Wood's Avatar
Rewards Points: 6
Everyone knows you're supposed to use a grinder to cut open empty tanks.
Morning Wood is offline
The Following User Says Thank You to Morning Wood For This Useful Post:
ScipioAfricanus (05-13-2015)
Old 05-13-2015, 05:40 AM   #45
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
My old boss used to smoke next to open gas lines. Used to freak me out as I had just started and didn't know a thing about gas. Couple weeks on and didn't bother me at all. Never did see one ignite from it.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-13-2015, 05:45 AM   #46
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
if you are close enough you never will..
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
pinwheel (05-13-2015), Xtrememtnbiker (05-13-2015)
Old 05-13-2015, 07:23 AM   #47
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Unless you invert the tank with an open valve...
Yeah wouldn't want to get that Trex stuff wet.
Inner10 is offline
Old 05-13-2015, 08:35 AM   #48
Texas Wax's Avatar
Unless you invert the tank with an open valve....
And the LP gas would "fall" out due to gravity. Seeing as how the specific gravity of LP is heavier than air.
Old 05-13-2015, 09:28 AM   #49
GC/carpenter
Calidecks's Avatar
Rewards Points: 158
I was remodeling an upstairs masterbath. After I had already built his deck.
Old 05-13-2015, 09:29 AM   #50
GC/carpenter
Calidecks's Avatar
Rewards Points: 158
My plumber checks for leaks on gas lines with a lighter,
Old 05-13-2015, 10:02 AM   #51
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 654
I did that once when checking for a leak under my house.
Must have been leaking for quite a while, blew the whole thing up, all walls gone, roof blown to pieces and I died.
Andy.
ScipioAfricanus is offline
The Following 3 Users Say Thank You to ScipioAfricanus For This Useful Post:
donerightwyo (11-11-2015), Tom Struble (05-13-2015), Xtrememtnbiker (05-13-2015)
Old 05-13-2015, 10:08 AM   #52
I own stock in FotoMat!
480sparky's Avatar
Rewards Points: 18
I go plinking with some buddies and use the empties as targets. Sometimes there's a bit of gas left in them, and if the round sparks just right while striking the tank, you get a really nice 'kaboom!'
This post has been modified from its original version. It has been formatted to fit this screen and edited for content.
480sparky is online now
Old 05-13-2015, 10:10 AM   #53
GC/carpenter
Calidecks's Avatar
Rewards Points: 158
Maybe I should of clarified it was on new installs.
Old 05-13-2015, 11:18 AM   #54
Inner10's Avatar
That's impossible according to BC.
Inner10 is offline
Old 05-13-2015, 12:05 PM   #55
Trade: Construction
Not impossible. Just don't happen very often at all. Happens even less on empty bottles.
We have shot them with everything from S&W 500, shotguns, 308's, 9mm, 45's, 5.56, 30-06 and with everything from tracers to "armor piecing" and not one blown up yet. But then again I was not in a movie when shooting them.
Old 05-13-2015, 05:58 PM   #56
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
My trash guys tell me if it's empty, just chuck it in the trash...and that's exactly what I do.
supersealconstruction.com
superseal is offline
Old 05-13-2015, 06:01 PM   #57
GC/carpenter
Calidecks's Avatar
Rewards Points: 158
That's exactly what I did
Old 11-11-2015, 10:07 PM   #58
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 452
shoot them
Lunicy is offline
Old 11-12-2015, 01:02 AM   #59
Designer/Contractor
Rio's Avatar
Rewards Points: 62
In the recycle can of the trash...............
Rio is online now
