Work On Tanks When Full? - Sandblasting - Contractor Talk
Old 09-01-2010, 06:14 AM   #1
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Doing a bid for a small company, but I am sceptical about blasting on a fuel tank when there full.
tanks have #2 and diesel in them (no propane or gas)
for you guys that do big tanks, Do you ground off the tanks before blasting them? They should be grounded any how, But wondering if a second ground for back up is needed?
any concerns about HOT Work on tanks?
I've done many small mobile truck tankers with no problems, Just need some ammo for the meeting in a few days.
I don't want to look unprofesional.
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 09-01-2010, 06:56 AM   #2
JohnnysMB's Avatar
Trade: Mobile Media Blasting
Rewards Points: 75
Re: Work On Tanks When Full?
I love some of the jobs you get. I don't see how them being full would hurt anything especially with deisel. However those could be famous last words before a nuclear explosion takes place. Would the constant vibration of the tank from the blasting do anything bad???
JohnnysMB is offline
Old 09-01-2010, 10:03 AM   #3
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Blast them full. Done many of them. From 5,000gal to 5,000,000gal. No.2 fuel oil, your not going to explode them. And yes, they should be grounded to earth already, but it's always safe to verify that they are.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is online now
The Following User Says Thank You to painter213 For This Useful Post:
Dyer (09-01-2010)
Old 09-01-2010, 10:16 AM   #4
Sar-Con's Avatar
Trade: Civil Construction, Excavation, Concrete + Forming
Rewards Points: 504
There is definitely concerns with hot work on tanks. The work can be done, but all risks have to be considered and mitigated. Here's a video from the CSB showing the dangers of hot work.
http://www.csb.gov/videoroom/detail.aspx?VID=44
Do the research, find the right procedure and away you go.
Sar-Con is offline
The Following User Says Thank You to Sar-Con For This Useful Post:
Dyer (09-01-2010)
Old 09-01-2010, 10:32 AM   #5
Sar-Con's Avatar
Rewards Points: 504
Here's a link to the website: http://www.csb.gov/default.aspx
If you search for the following bulletin, they've got some good info. The file was too big too attach. ( I've attached the summary only )
2010 Feb - CSB Hot Work Safety Bulletin - 7 lessons.pdf
Sar-Con is offline
Dyer (09-01-2010)
Old 09-01-2010, 10:38 AM   #6
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
"They said it was a...."
"So we decided to use an Acetylene...."
"Burned over 90% of my body...."
Mystery how this occurred!
Work smart. Work SAFE!
Ultimate Wisdom---------
MALCO.New.York is offline
The Following User Says Thank You to MALCO.New.York For This Useful Post:
Dyer (09-01-2010)
Old 09-01-2010, 03:10 PM   #7
Master Blaster!
BLASTPRO's Avatar
Trade: Sandblasting and Coatings
Rewards Points: 150
We blast tanks all summer long. Gas, Diesel, Fertilizer, Anhydrous, LP, Propane what ever. We always and I mean always plastic and tape shut the relief valves and vents on the top of the tank. You have to unseal them as soon as your done blasting. We have never had a problem and have done hundreds of tanks.
BLASTPRO is offline
The Following User Says Thank You to BLASTPRO For This Useful Post:
Dyer (09-01-2010)
Old 09-01-2010, 07:41 PM   #8
Dyer's Avatar
Rewards Points: 864
Just for notes:
we are just doing tops and skerting around
nothing under or inside.
I forgot to add this earier.
Thanks for all the replies, I grately appreciate it guys.
Dyer is offline
Old 09-07-2010, 07:25 PM   #9
Dyer's Avatar
Rewards Points: 864
Still working on priceing for spent grit
so far we found a local waste remover that will drop of a slide dump that will hold 12,000 lbs for $65
pick up and deliver to land fill (if not Has Mat) 350.
Liner 45.
and dump fees at 65 per ton.
TCLP fees are 260.
if its haz, they have to hall it to Mass? (for extra)
Owner of the tanks is paying for all of this, just thought I'd share.
Dyer is offline
Old 09-19-2010, 09:52 AM   #10
Mr Blaster
mrblaster's Avatar
Trade: Sandblasting Protective Finishes
Rewards Points: 75
I also do alot of LP, anhydrous, and diesel tanks and have never had a problem. The biggest concearn they have is that I double wrap aluminum tape around shut off valves to protect the valve seal. I lightly go around them when blasting. No issues or problems. Most of the items I blast are on chasis, with the tires still on so I use that as my ground. Havent blown up to date.
mrblaster is offline
Old 09-19-2010, 10:18 PM   #11
Kelly
kell490's Avatar
Trade: Media blasting
Rewards Points: 254
I see a lot of sparking when blasting either from static or just the glass hitting something. I'm assuming if a vent is open somewhere it could ignite. Is there a way to control the static seems to be worse now that I'm using a plastic style Schmidt nozzle instead of the short steel one.
kell490 is offline
Old 09-20-2010, 02:08 AM   #12
A. Spruce's Avatar
Trade: General Contractor - ret.
I can't say for blasting, but I can say that dust collection systems that use plastic pipe for the conduits creates static charges that have to be grounded to prevent ignition of wood dust in the air stream and containment systems. As air passes through plastic, a static charge is created, it is a fact of life when using plastic components. The only way around the static charge is to ground it out away from ignition points, in the case of dust collection, a bare copper wire is run through the ducting and grounded at regular intervals between the collection point and the storage point. Can't say how such a grounding implementation could be arranged with a blasting set up.
A. Spruce is offline
Looking for work southern dutchess county NY "JJ" Help Wanted or Looking For Work 1 05-25-2010 01:03 PM
Looking for work.... THINKPAINTING General Discussion 2 02-10-2010 03:42 PM
Looking for Work in the MI area esterline00 Help Wanted or Looking For Work 45 03-02-2009 11:08 AM
Hiring office work/paper work people? J-Peffer Roofing 3 06-22-2008 10:22 AM
In answer to a closed thread. AAPaint donb1959 Painting & Finish Work 42 08-27-2006 12:36 AM
