Window Masking On Homes. What Are You Using? - Sandblasting - Contractor Talk
Old 10-11-2015, 09:21 AM   #1
ratherberacin's Avatar
Trade: media blaster
Rewards Points: 270
for you guys doing log/wood homes. I am having a hard time finding a tape that doesn't leave glue behind on windows. I have been using green painters tape followed by tuct tape (ugly if it gets on the glass) or duct tape and poly. the painters tape works well as long as it doesn't get hit with media. then its a nightmare to remove too.
is there a better, faster, easier way?
ratherberacin is offline
Old 10-12-2015, 06:02 AM   #2
Hiber's Avatar
Rewards Points: 60
Re: Window Masking On Homes. What Are You Using?
I don't know a thing about sandblasting but maybe liquid mask the glass then duct tape to that when its dry. The film peals right off when your done.
Hiber is offline
Old 10-13-2015, 06:10 AM   #3
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Depending on the trim on the homes, wood plastic or aluminum.
Using auto body yellow tape (like painters bile tape but sticky) for under layment, then 3mil plastic in middle of window stick down sides of plastic with boat shrink wrap tape 2 or 4".
Leaves no residues.
As a hint..
1. Do not put large area of shrink wrap tape to glass it sticks really really good and comes of hard.
2. When putting yellow tape on window, leave a 1/2" of window open between sides for boat tape to stick to glass. So plastic will not blow off.
3. Use a painters metal spray shield to block blast over spray from hitting glass or trim.
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 10-13-2015, 06:05 PM   #4
MasterBlaster's Avatar
Trade: DUST FREE Media Blasting and Sandblasting
Rewards Points: 838
I switched to walnut shells for blasting log and cedar homes.
Walnuts don't etch glass... so I save time not having to tape the glass.... PLUS I can recycle the walnuts up to 4 times by reclaiming and rescreening it for use the next day.
Just did this house last week
Before:
After:
Before:
After:
Before:
After:
Before:
After:
All done with walnut shells!
MasterBlaster is offline
The Following User Says Thank You to MasterBlaster For This Useful Post:
overanalyze (10-13-2015)
Old 10-13-2015, 06:14 PM   #5
CompleteW&D's Avatar
Trade: Windows, Doors, Siding, Enclosures
Rewards Points: 2,936
Wow.... that looks GOOD!!!
- John Williams
Complete Window and Door
Originally Posted by TNTSERVICES View Post
As accomplishments go, getting me to talk is an easy one.
CompleteW&D is offline
Old 10-13-2015, 07:30 PM   #6
Rewards Points: 270
thanks for the replies guys.
Master, no problems with your stain companies using walnut or cob on houses? my stain guys will not warranty a organic product shot on wood. I am told it will mold eventually and the stain will fail.
im not in the stain world so I don't know, I am just told by the companies who hire me it has to be glass or garnet. timber pro is one stain who will not endorse or warranty any organic style media.
Old 10-14-2015, 05:32 AM   #7
Rewards Points: 838
No, I haven't had any problems with stain company warranties... I suppose I'll have to look into that.
Isn't wood organic?
Old 10-14-2015, 11:20 PM   #8
Rewards Points: 270
wood is organic but it being impregnated by another different organic matter (that sounds so dirty) I am on the timber pro list of approved blasters (whatever that means, they have never given me any work) and his first lecture was no walnut or cob at all with their products as it will mold if that stuff is stuck in the cracks. siding I don't see a big issue its log that would be a bigger problem I think.
maybe they just make bad stain? id like to talk to the big stain companies and see what they say. perma-chink sells cob and stain so must not be a issue with them but would be good to know for sure.
ill do some research too
Old 10-15-2015, 08:46 AM   #9
Rewards Points: 270
perma-chink no longer lists cob on their site. I emailed Behr, perma chink and sikkens and will post what I get back.
Old 10-15-2015, 10:59 AM   #10
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Stucco tape is designed for this purpose - it's red, white or black and quite shiny, not the duct tape cloth style, but polyethylene.
I use it for everything these days and love it.
http://www.electrotape.com/polyethyl...ucco-tape.aspx
supersealconstruction.com
superseal is offline
Old 10-16-2015, 08:56 AM   #11
Rewards Points: 270
thanks super, I am checking on a dealer in Canada.
Master.
got some responses.
Behr stain says. (I said I blasted with glass, but was curious about organic medias)
" Media blasting isnít something weíve tested with our wood stains however I can understand the concern with mold growing on the surface after staining. Since youíre using crushed glass though, we donít see this being an issue. Normally the recommended ways to remove our stains would be to use a paint stripper, sanding, or power washing (on a low setting). "
Sikkens says
Thanks for contacting PPG Sikkens\ProLuxe Technical Service Department. Using any carbon based organic materials for media blasting can lead to material being inject or infused into the wood substrate. The material itself can later become a food source for any mildew or mold formation, provide the environmental conditions are conducive to the formation.
The use of the organic media, is a great way of removing a finish without damage to the substrate and we have recommend such media many times, provided that after the removal of the stain, the wood be cleaned and sterilized using 4 ounce of TSP, mixed with 1 quart of outdoor bleach and 3 quarts of potable water. The cleaning solution is then removed with a light pressure washing at less than 500 psi and allowed to dry for at least 3 good drying days.
just like any other job we do I suppose just be careful. good info though
Old 10-16-2015, 04:35 PM   #12
Rewards Points: 838
Good stuff ratherberacin!
One other note and that is there is a big difference between walnut shells and corncob, corncob does hold moisture while walnut shells are hard just like wood that's being blasted and don't really hold moisture.
I suppose bleach and water followed by pressure washing is the answer.
Thanks
Old 11-28-2015, 10:07 PM   #13
kblh1964's Avatar
Rewards Points: 12
I have used Frog tape and cut a cardboard and held it when using glass media but I do not tape windows or doors when using Corn or Walnut .
I did switch to a Fan tip nozzle for Glass use this last time and found windows and door trim easier to remove failed stain .
I haven`t had issues with mold since after my first blast job with Corn cob .
I had some small piles about maybe 16 oz is size that molded and since then I do a better job of clean-up but it was not on the wood but on the ground .
Since we stained it we just cleaned the wood of any media in checks or crevices with a air nozzle or brush .
kblh1964 is offline
Old 03-21-2016, 09:29 AM   #14
Phatboy's Avatar
Trade: Superintendent
Rewards Points: 26
Wow, Nice work !
Phatboy is offline
Old 03-30-2016, 07:57 PM   #15
Tjlugar's Avatar
Trade: Sandblasting
Hey guys any advice on what and how to bid on these gates? I'm very new to the industry
window masking on homes. what are you using?-image_1459385746808.png   window masking on homes. what are you using?-image_1459385780402.png
Tjlugar is offline
Old 03-30-2016, 09:59 PM   #16
VinylHanger's Avatar
Rewards Points: 13,774
Didn't you just get spanked on another thread for asking about pricing?
What do gates have to do with window masking?
Sent from my SM-G935V using Tapatalk
VinylHanger is online now
Replacement Window Question? Max10 Windows, Siding and Doors 41 11-03-2013 12:01 PM
how should I trim out the window siding?? lewisthepilgrim Windows, Siding and Doors 24 12-02-2012 11:46 AM
Hud announces $13 million in grants to protect kids from lead paint Brickie General Discussion 22 05-15-2010 02:09 PM
The House of Tomorrow from the Recession Today NC2X4 General Discussion 11 02-28-2009 05:05 PM
