What To Use???? - Sandblasting - Contractor Talk
What To Use????
Old 11-22-2010, 09:15 PM   #1
Nita
MO_Blast_Momma's Avatar
Trade: Media Blasting
What To Use????
New to the forum and pretty much a newbie at blasting. Wondering how you decide what media to use if customer DOESN'T have a preference? Did have one guy just have to have crushed walnut... was on '41(?) Ford jeep. Didn't get the result I would have preferred, but he stood and watched the whole time saying "That's good enough;... don't worry about that side " Small job, but every little bit of experience helps.
Saw a post by "Betterblast" earlier this year using walnut on an Impala hood... wondering if you chose that media, Glen or did customer request it? And why?
We haven't really advertised much, but do have a yellow page ad coming out in local lake area phone book soon. Never blasted any boats. We have used Super K on old cars, but no longer cost effective. We have a pallet of Walnut from Surface Tek and a pallet of Natrium 260 soda. After finding this website, wondering if we shouldn't have gotten fine, crushed glass instead of soda (we also have some medium crushed glass).
Any advice is good advice.....
MO_Blast_Momma is offline
Old 11-23-2010, 12:51 AM   #2
nbjornson
nbjornson's Avatar
Trade: Abrasive Blasting
Re: What To Use????
Hello,
In regards to your question about abrasive in this application. Alot of customers use bi-carb (baking soda) from Natrium or Armex. However alot alos use Plastic. The reason is that plastic can be recycled and is normally used in a blast room where bi-carb is a one use media and challenging / expensive to convey, and expensive to purchase since it is one use. Walnut shells can also be used but expect it to take longer than plastic. Plastic will not harm the substrate either but it is angular so it works by cutting action. Hope this helps some.
nbjornson is offline
The Following User Says Thank You to nbjornson For This Useful Post:
MO_Blast_Momma (11-23-2010)
Old 11-23-2010, 01:00 AM   #3
ratherberacin's Avatar
Trade: media blaster
Rewards Points: 270
Re: What To Use????
i originally bought my problast (same as surface tek) pot and fell into the "soda does it all" sales pitch. It took me about a week to figure out that wasnt true. so. tried walnuts. i have had zero luck blasting with them as they are way too slow. i have 500 or so pounds here so may try again. i do want to make them work so will keep trying
crushed glass. i use more glass than anything else now. natrium soda on the fragile stuff and glass on the rest. i use mostly 50-100 as i dont blast any really rusty industrial stuff. (i leave that to the $70/hr guys)
ratherberacin is offline
The Following User Says Thank You to ratherberacin For This Useful Post:
Old 11-23-2010, 05:23 AM   #4
ausisoda's Avatar
Trade: abrassive blasting
Re: What To Use????
Originally Posted by nbjornson View Post
Hello,
What type of plastic media would you recommend for auto work?
Would melamine be the most affective or acrylic or urea?
I am interested in this also.
How many times can the media be reused?
Thank you for the info on the hodge clemco products. I have been talking to there sales rep and they seem very professional. I will be buying a unit through them very soon.
ausisoda is offline
Old 11-24-2010, 10:58 AM   #5
nbjornson
nbjornson's Avatar
Re: What To Use????
Alot of customers use urea type II maybe a 20/30 mesh. You will get about 6-8 passes out of the abrasive before it breaks down. Typical blast pressure about 40-60 psi. No need to work higher than that.
Old 11-24-2010, 02:42 PM   #6
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
Re: What To Use????
Hello Mo Blast, The customer didn't want any chance of warping and there wasn't rust to be concerned with so I chose walnut. I have soda but then there are the paint issues. I save the soda for boats and around engines and such.
Rather, I just put a post on Jim's "show us your work" thread of a recent walnut blast.
When it has to be clean, Betterblast it!
[email protected]
P-610-323-8084
http://betterblast.com/
Betterblast is offline
The Following User Says Thank You to Betterblast For This Useful Post:
MO_Blast_Momma (11-24-2010)
Old 11-24-2010, 04:31 PM   #7
ausisoda's Avatar
Re: What To Use????
I called a few suppliers yesterday and plastic is out of the question in my overpriced country it is sold buy the kilo and costs $8.00 per kilo
So walnut and glass for me I think.
I should have my pot in 6 weeks time
ausisoda is offline
Old 11-28-2010, 09:43 PM   #8
Kelly
kell490's Avatar
Rewards Points: 254
Re: What To Use????
I have blasted several cars now with 70 grit at 35-40psi no warping what so ever it leaves a very nice finish ready for primer. I don't have a blast room so have never tried plastic or walnut. I would suggest you run an ad either in craigslist or local cheap paper to find some junk car body parts. Hoods, trunk lids, or the junk yard. I find it cheaper in craigslist then at the junk yard. I do all my testing on this stuff. Someone that is parting out a Toyota from the 80's or 90's. It takes some practice and you shouldn't really do that on customers cars. I too was sold on the "warping worry" into buying the magic soda. Soda is good for cleaning barbecues this is what I used it on last. I bought an old nasty weber out of craigslist and with soda and water it was like new. I still have a pallet of soda to use I'm thinking of selling most of it since I don't use it much.
kell490 is offline
Old 11-29-2010, 06:37 AM   #9
Glen
Rewards Points: 686
Re: What To Use????
I've also used glass on auto parts with no sign of warping but it is a possibility. Mostly giving the customer the choice lets some of the responsibility off of your shoulders since you can just do the best you can. Another difference with the non abrasives is somtimes they will leave the chrome drip moldings on or glass or door handles... The crushed glass will etch those so be carefull.
[email protected]
P-610-323-8084
Old 12-05-2010, 08:04 PM   #10
JohnnysMB's Avatar
Trade: Mobile Media Blasting
Rewards Points: 75
Re: What To Use????
If the customer doesn't have a preference or an uninformed preference. I recommend what I know will have great results with the lowest cost to me and easiest cleanup. Like most I LOVE glass. On industrial stuff I've used some Nickel Slag that I get for half the price of glass and works really well.
John
JohnnysMB is offline
