Toyota Titan Rims - Sandblasting - Contractor Talk
Toyota Titan Rims
Old 04-07-2015, 05:32 PM   #1
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Toyota Titan Rims
Got a guy that want his rims blasted on a
Toyota Titan
he just called concerned about the rims having a
special coating that can't be blasted? ??
Anyone have info on these things
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 04-07-2015, 05:36 PM   #2
Roofcheck's Avatar
Trade: Know it all
Rewards Points: 2,054
Re: Toyota Titan Rims
Toyota Tundra
Nissan Titan
Roofcheck is offline
The Following 2 Users Say Thank You to Roofcheck For This Useful Post:
BCConstruction (04-07-2015), Dyer (04-07-2015)
Old 04-07-2015, 05:53 PM   #3
Dyer's Avatar
Rewards Points: 864
Originally Posted by Roofcheck View Post
Toyota Tundra
Nissan Titan
Ya I own Chevy. Lol
Its the newest Toyota truck they make? ???
Guess there aluminum alloy
Dyer is offline
Old 04-07-2015, 06:09 PM   #4
Todd
blastserv's Avatar
Trade: media blasting
Rewards Points: 762
Aluminum...with usually powder for a color and a clear powder over top. Good times 30 minutes per wheel...can be an hour a wheel...bid wisely!
www.blastserv.com
blastserv is offline
The Following User Says Thank You to blastserv For This Useful Post:
Dyer (04-07-2015)
Old 04-07-2015, 06:32 PM   #5
Dyer's Avatar
Rewards Points: 864
Todd can these be done with fine glass to give etch for repowder coating
Dyer is offline
Old 04-07-2015, 07:07 PM   #6
Todd
blastserv's Avatar
Rewards Points: 762
Sure! Just remember the finer the media the longer you spend working on one. Definitely I fine tipping point of worth it/not worth it on some of these wheels.
New camaro wheels are tough to see the value in taking those on as a blaster...
www.blastserv.com
Old 04-07-2015, 07:53 PM   #7
Blast Off's Avatar
Trade: Media Blasting
Rewards Points: 275
The last set of powder coated rims I ended up switching to Starolite, New Age medium grit wasn't cutting it, pun intended. Those were Subaru aluminum rims with powder and clear coats.
You can try to bake the powder coat off before blasting with one of those propane tar/ice melting gun thingys.
"Hokey religions and ancient weapons are no match for a good blaster at your side kid."
Blast Off is offline
Old 04-07-2015, 09:45 PM   #8
Dyer's Avatar
Rewards Points: 864
I've done alot of rims guys,steel and aluminum.
This guy seemed to indicate that they are a special type... Aluminum alloy
I guess im going to do them with the glass that I always used 30/60
he was told by someone that they shouldn't be blasted?
They seem to be a rubber type paint on them.
I did find out that the guy having them blasted, his customer is a long time friend
Growing up. Lol. Small world.
Ill try glass. Fall back plan is soda
Ill post pictures for all following
Dyer is offline
Old 04-08-2015, 03:33 PM   #9
Dyer's Avatar
Rewards Points: 864
Yes it's a Nissan Titan truck
rims are done.
Had a rubber coating on the face of the rim.
came off slow but not bad or not like undercoating.
In the end. They look like aluminum rims blasted eith glasd...lol
Toyota Titan rims-20150408_154124.jpg   Toyota Titan rims-20150408_152827.jpg   Toyota Titan rims-20150408_153226.jpg
Dyer is offline
Werkmaster Titan Concrete Grinder/ Polishing Machine StainConcrete Contractor Swap 0 03-05-2014 03:59 PM
Toyota Tundra CrewMax BDB Vehicles 32 12-22-2012 08:44 PM
Titan 440i Filter Replace artinall Painting & Finish Work 10 07-24-2012 10:15 PM
new titan 440 impact question. tpainting Painting & Finish Work 3 03-27-2011 07:11 PM
Are Graco and Titan compatible? blackstone General Discussion 4 04-19-2009 08:05 PM
