Shot Blasters - Sandblasting - Contractor Talk
Shot Blasters
Old 06-07-2014, 05:51 AM   #1
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Shot Blasters
IT's been a long time since I've used a shot blaster in the ship yard....
I'm pricing a job for a metal deck walk way, out side 7' x 260' long and it's over water.
Deck it solid plate.... Has rust and non skid flaking off..
Shot blasting I feel is the only way to get it done.
I'm going to rent, and only place is sunbelt rentals that has them.
So, I know they use them a lot for concrete floors
I need to know if anyone's used or has one
And what I'll need to use them
It say 220v for the machine but will I need to rent a diesel gen to run the driver and air vac ?
Steel shot or steel grit ( sharp) ?
Give me some Insite to help out guys
Thanks
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 06-07-2014, 09:49 AM   #2
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Re: Shot Blasters
Steel grit will probably get you in trouble with the rental company as it really tears them up bad. What you'll need to run it will depend on the size that you get. Sunbelt should have everything that you'll need to run it though. I'd get with them first and then go by and look at everything before I'd rent.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 06-07-2014, 09:45 PM   #3
Dyer's Avatar
Rewards Points: 864
Re: Shot Blasters
Thanks Benny
Dyer is offline
Old 06-08-2014, 12:11 AM   #4
painter213's Avatar
Re: Shot Blasters
Your welcome man!
[email protected]
205-717-0292
Old 06-08-2014, 05:33 AM   #5
Dyer's Avatar
Rewards Points: 864
Re: Shot Blasters
Few pictures of the job
Haven't bid yet, want sll my ducks in a row first lol
Dyer is offline
Old 06-08-2014, 03:18 PM   #6
Todd
blastserv's Avatar
Trade: media blasting
Rewards Points: 762
Re: Shot Blasters
I have used them and yes sunbelt has them. Try and locate a propane powered unit for that job. Not sure of total access in and out but with out seeing the area to enter it might be difficult to access. They usually have a dust containment all in one. It's a drive on unit. Not cheap to rent for a day either nor is the steel shot. I do however think you are in the right direction for that job.
Good luck Jim!
www.blastserv.com
blastserv is offline
The Following User Says Thank You to blastserv For This Useful Post:
Dyer (06-08-2014)
Old 06-15-2014, 08:12 PM   #7
any media master blaster
wesschaff's Avatar
Trade: sand blastiing
Rewards Points: 158
Re: Shot Blasters
I did 50+k sq ft with a sit on. unit was propane powered pm me andIi will find the name of co that I rented from.You have to use the right unit the one I used did 10 inches at a pass the larger unit was a P.O.S. it literally blewup upon its first pass.
Wes
www.green-surface-solutions.com
wesschaff is offline
The Following User Says Thank You to wesschaff For This Useful Post:
Dyer (06-16-2014)
Old 06-16-2014, 01:46 AM   #8
wesschaff's Avatar
Rewards Points: 158
Re: Shot Blasters
After looking at your picture again I think you might want to use a sit on scraper unit ,the non skid might be too thick for a shot blast machine
Wes
any blasters here around Pittsburgh ratherberacin Sandblasting 1 05-24-2013 09:13 AM
Router bearings shot? dkillianjr Tools & Equipment 8 03-14-2013 11:06 PM
Blasters for sale ibsocal Sandblasting 0 12-11-2012 12:48 AM
DJI shot up today 206.51....... PrestigeR&D Off Topic (Non Trade) 7 09-14-2012 11:58 AM
Small / Affordable blasters Balzomedic Sandblasting 2 07-29-2012 01:14 PM
