Phil In NJ.... - Sandblasting - Contractor Talk
Phil In NJ....
Old 11-22-2013, 09:26 AM   #1
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Phil In NJ....
Phil you didn't leave me a Phone Number to get back to you???
did you get your compressor running???
Jim
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 11-27-2013, 02:42 PM   #2
any media master blaster
wesschaff's Avatar
Trade: sand blastiing
Rewards Points: 158
Re: Phil In NJ....
Hi Jim,
We switched out to another IR unit, we were losing pressure and volume when pot called for air.The job turned out ok ,we were taking the polished surface off of granite so it could be used as tiles that would be walked on.Thanks for the interest.
Wes
www.green-surface-solutions.com
wesschaff is offline
Old 11-27-2013, 03:05 PM   #3
Dyer's Avatar
Rewards Points: 864
Re: Phil In NJ....
Ya, I got home and saw the call just didn't know your number With IR, on top of the air oil sep, the line that runs out and goes to equipment.... There is a valve that adjust the pressure It's small in size but has height to it with a screw on top ( and a lock nut) I adjust mine all the time Last few years in the winter I've sucked up the air oil filters cause of it, the tech's that work on them didn't know it either. When running I turn compressor mine up to 130 psi.
Before shutting down, I turn it back to 80 -90 psi This keeps the compressor from working to hard on start up, in cold weather the low psi switch doesn't always kick in and it will start up on high causing the filter to collapse When I'm talking low temp I mean 35 f and under Inside that valve adjustment There is a small o ring that if it goes, will not let you adjust it - or very little this to will suck your filter up... I've replaced mine 4 times at 200 each, Clock wise- psi up Counter click wise - down Make sure you do it in very little incriminates Last year I turned it down every time before shutting off and did not have any problems, but hey, I've got the best luck and it might change Lol
Dyer is offline
Phil Humber Pitches Perfect Game GRB Off Topic (Non Trade) 7 04-21-2012 06:24 PM
Phil Harris (deadliest catch dies) BCConstruction Off Topic (Non Trade) 11 02-20-2010 06:51 AM
Punxutawney Phil? Kent Whitten Off Topic (Non Trade) 5 03-14-2009 04:15 AM
phil rea vinylguy Business 6 04-28-2006 07:29 AM
