New To Sandblasting - Sandblasting - Contractor Talk
New To Sandblasting
Old 01-27-2013, 01:36 PM   #1
rmsls1's Avatar
Trade: Maintenance
New To Sandblasting
I am new to this forum and have acquired some equipment over the years. I have a Clemco 150 (3 cu.ft.) sand pot, and IR Compressor G85. 85 CFM. It has to two 3/4" outlet air connections.
Bulllard positive air helmet. I am looking to complete my setup so I can begin blasting.
The sand pot has 1-1/4" pipe. I have the deadman valve and twinline. I need to get a hose and nozzle. I am also looking for a air supply, like Bullard's free air,
Can anybody tell me what size hose and and nozzle tips I need?
rmsls1 is offline
Old 01-27-2013, 02:37 PM   #2
any media master blaster
wesschaff's Avatar
Trade: sand blastiing
Rewards Points: 158
Re: New To Sandblasting
Your gonna need 1/4 inch nozzle and 3/4 inch line your setup might be good for small metal parts and signs but not larger projects because the 85 cfm unit will limit your blast pattern.
Wes
www.green-surface-solutions.com
wesschaff is offline
Old 01-27-2013, 11:14 PM   #3
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
You are going to out grow that fast. Start looking around for at least a 185 to 210 cfm so you can bump up to a 5 or 6 nozzle as you get busy. Go with a nova 2000 helmet from jadcousa.com
When it has to be clean, Betterblast it!
[email protected]
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 01-31-2013, 12:11 PM   #4
rmsls1's Avatar
Trade: Maintenance
Thanks for the information on the 3/4" blasting hose line and 1/4" nozzel. Since I have a sandpot with 1-1/4" is it ok to just use a carbon steel pipe reducer/nipple to get to 3/4" for my blast hose?
rmsls1 is offline
Old 01-31-2013, 08:05 PM   #5
wesschaff's Avatar
Rewards Points: 158
Sure it will be fine.
You might even be able to use next size up nozzle, it could give you a larger patten.
I used a 115 cfm compressor one year made 50k with it.
Also just rent a 185 or larger when you get a job that needs it, I still do that.
We recently finished a 15k sq ft structural steel job with a rented 205 cfm.
Had a 400 cfm for one day on the job it did no better,it used to much fuel and abrasive.Same pots and nozzles. So you don't need to go large to get started.
Wes
Old 01-31-2013, 11:26 PM   #6
rmsls1's Avatar
Trade: Maintenance
Thanks for the encouragement Wes. I was beginning to wonder if I was wasting my time. I plan to start small doing odd jobs for fellow car restorers, like rear axles, frames. I will leave the car bodies to those that know what they are doing. I also have some steel work that needs to be cleaned up for a metal building.
rmsls1 is offline
Old 02-01-2013, 05:25 PM   #7
wesschaff's Avatar
Rewards Points: 158
That's it start small and rent what you need, any job worthwhile can have enuff profit for some rental equipment.
Many have invested big time only to find that this business is not for them.
Good idea to stick with small parts, do them and when you are comfortable with the results rent a larger compressor for the steel work.
Wes
Old 02-02-2013, 03:54 AM   #8
ausisoda's Avatar
Trade: abrassive blasting
It would have done better if your equipment is sized to that compressor.
If you only use regular blasting pots they are mostly rated for a no6 nozzle max.
The difference is night and day running a no7 or no8 compared to a no5 or no6 nozzle.
ABSS supplies.
For a bullet proof blasting machine made in Australia they should be your first choice.
They produce top quality equipment that will give you hours of trouble free blasting.
Their customer service is the best in the business.
ausisoda is offline
Old 02-07-2013, 12:02 AM   #9
LogHome's Avatar
Rewards Points: 135
Good luck with the sandblasting. There is always work if you have a sand blast set up.
LogHome is offline
Looking to trade Sandblasting Pot.... rbob Contractor Swap 0 08-02-2012 09:42 AM
Sandblasting Equipment For Sale rbob Contractor Swap 0 11-17-2011 11:20 AM
6 Ton P & G Sandblasting Pot For Sale rbob Contractor Swap 0 11-17-2011 09:32 AM
Sandblasting Equipment For Sale rbob Contractor Swap 0 08-01-2011 11:10 AM
Sandblasting Pots For Sale rbob Contractor Swap 0 03-04-2011 04:16 PM
