Mopped Tar Ashphalt - Sandblasting - Contractor Talk
Mopped Tar Ashphalt
Old 02-10-2015, 10:35 AM   #1
blastoffinc's Avatar
Trade: Sodablasting/ Sandblasting
Rewards Points: 200
Mopped Tar Ashphalt
Has anyone ever dealt with removing mopped tar ashphalt from an inground pool. I have a request for Bid and I have never dealt with it.
blastoffinc is offline
Old 02-10-2015, 02:08 PM   #2
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Re: Mopped Tar Ashphalt
In cold weather if it's not too thick it should blast off fairly well. In warm weather your screwed. Even in cold weather a air chisel works very well to remove the mass and then come back and abrasive blast to finish removing it.
Never ran into it in a pool but many years ago it was in a lot of water tanks. It could be well over two inches thick down in the belly portion of the tank and was a blasters worse nightmare.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 02-10-2015, 02:17 PM   #3
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
If it's thin blast it off, if its thick scrape it first. If it has reinforcing in it scrape it.
1985gt is offline
Old 02-10-2015, 02:21 PM   #4
Rewards Points: 200
What would be the best way to scrape it? It's about 4,000 sq. Ft. I'm told it's about an 1/8" thick.
Old 02-10-2015, 02:26 PM   #5
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
Something like this would work well.
http://www.floor-equipment.com/parts...ar-detail.html
Walls, floor or both?
What is going to go on after the asphalt is scraped?
1985gt is offline
The Following User Says Thank You to 1985gt For This Useful Post:
MasterBlaster (02-13-2015)
Old 02-10-2015, 02:33 PM   #6
Rewards Points: 200
It's just on the walls and they're going to do some type of coating over it, I'm not sure what.
Old 02-10-2015, 02:42 PM   #7
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
They may have some kind of primer for it also, once it is scraped of the heavy stuff they may be able to just prime it. I'd think blasting it after scraping will take a long time as they likely primed the concrete and that isn't known for coming off very easy.
1985gt is offline
Old 02-11-2015, 08:57 PM   #8
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Would dry ice work on that stuff.
had a local guy in the cement plants removing
old splash over, said the cold made it brittle and
came off in chunks.
would it work on tar the same??
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: DyerSodaBla[email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 02-11-2015, 09:11 PM   #9
Rewards Points: 200
I'm wondering this too. I have a call into cold jet to find out.
Old 02-11-2015, 10:21 PM   #10
painter213's Avatar
Not sure. It might do it. Pretty sure it would slow go, but might just do it.
[email protected]
205-717-0292
Old 02-12-2015, 06:45 AM   #11
Dyer's Avatar
Rewards Points: 864
If its cold out like penny said, electric hammer with a wide blade to take off
The heavy, then dry ice after ??
Email: [email protected]
Dyer is offline
Old 02-14-2015, 08:53 AM   #12
salty's Avatar
Trade: media blasting
Rewards Points: 126
I did a small section at a fuel terminal on a tank . It came off nice with soda !! I gave them a price and they said they would think about it . I never got a call back . Price will change with warmer weather I have heard it's a bear to come off when hot .
salty is offline
Old 02-15-2015, 10:42 AM   #13
Rewards Points: 200
Soda? Hmm that's interesting. Any idea how thick it was? How much area did you get done in what amount of time?
Old 02-15-2015, 01:09 PM   #14
painter213's Avatar
That would had to been some hard soda to of removed mopped on coal tar.
[email protected]
205-717-0292
Old 02-15-2015, 01:20 PM   #15
Blast Off's Avatar
Trade: Media Blasting
Rewards Points: 275
I imagine the soda was getting under the tar pretty easily and peeling it off. The surface may not have been prepped well before applying the tar.
"Hokey religions and ancient weapons are no match for a good blaster at your side kid."
Blast Off is offline
Old 02-15-2015, 03:22 PM   #16
painter213's Avatar
Possible, but all the tar that I've been a part of on blasting wasn't that easy to come off. But these were mostly on the inside of potable water tanks and then the rest was inside of a coke plant where coke was produced. Lots and lots of coal slag was used. 10/40 and 12/40 mostly.
[email protected]
205-717-0292
Old 02-15-2015, 03:50 PM   #17
salty's Avatar
Rewards Points: 126
It was like 16 - 20 sq ft blasting it off tin structure . It was a spill over off a tank top . Also it was like 35 degrees
salty is offline
shower bench that has benn hot mopped careys Remodeling 30 04-03-2010 05:25 AM
