Lead Keel - Sandblasting - Contractor Talk
Lead Keel
Old 03-13-2015, 06:14 PM   #1
M&RMMB's Avatar
Rewards Points: 60
Lead Keel
Anyone ever blast a lead keel on a boat before? Wondering if it's a safe thing for me to do? Any input would be greatly appreciated!
M&RMMB is offline
Old 03-13-2015, 06:25 PM   #2
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Re: Lead Keel
I would have really say not a good idea. How would you dispose of the Haz Waste?
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 03-13-2015, 06:34 PM   #3
M&RMMB's Avatar
Rewards Points: 60
Re: Lead Keel
Thanks!! That's the part I was kind of afraid of. Other then masking off the area with plastic what other options are there or is that even enough? I guess a dumb question is why would they use that material on a boat anyway?
M&RMMB is offline
Old 03-13-2015, 06:54 PM   #4
painter213's Avatar
Re: Lead Keel
Not sure, I'd look at chemical stripping instead. If you remove any lead by blasting and your waste will all be haz mat.
[email protected]
205-717-0292
The Following User Says Thank You to painter213 For This Useful Post:
M&RMMB (03-13-2015)
Old 03-13-2015, 06:57 PM   #5
M&RMMB's Avatar
Rewards Points: 60
Re: Lead Keel
Yeah definitely out of my ability on that one. Thanks for your advice!
M&RMMB is offline
Old 03-13-2015, 07:02 PM   #6
Bob
Sand Pot's Avatar
Trade: Abrasive blasting
Rewards Points: 886
Re: Lead Keel
Lead has been used for sailboat keels for centuries. As a solid mass of material it is basically inert causing no harm to anyone or any creature. I blast them wet onto a tarp, some guys scrape them down, others sand them with discs (the stupid ones). Everything just gets tossed into the boatyard dumpster where all the other nasty stuff goes. Boatyards are the final wild frontier when it comes to environmental regs and controls
Sand Pot is offline
Old 03-13-2015, 07:08 PM   #7
M&RMMB's Avatar
Rewards Points: 60
Re: Lead Keel
That was my original plan doing it wet with some plastic barriers. I just don't to get myself into some EPA issues.
M&RMMB is offline
Old 03-13-2015, 07:20 PM   #8
Bob
Sand Pot's Avatar
Rewards Points: 886
Re: Lead Keel
BTW, lead keels are actually an alloy with antimony (as I recall) which makes them quite hard. Blasting them is more like blasting cast iron, the lead doesn't give itself up very easily, paint and growth comes of readily and you end up with very little metal on the ground.
Sand Pot is offline
The Following User Says Thank You to Sand Pot For This Useful Post:
M&RMMB (03-13-2015)
Old 03-13-2015, 07:33 PM   #9
hdavis's Avatar
Rewards Points: 4,636
Re: Lead Keel
The EPA has a short guide on how to comply with the rega in a marina. Google will find it.
hdavis is online now
Old 03-13-2015, 08:27 PM   #10
M&RMMB's Avatar
Rewards Points: 60
Re: Lead Keel
Thanks for the information.
M&RMMB is offline
The Following User Says Thank You to M&RMMB For This Useful Post:
hdavis (03-13-2015)
Old 03-14-2015, 06:24 AM   #11
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Re: Lead Keel
M&R
Your in Maine. You need to read the marina rules and regs on blasting in
The boat yards. All boats must be tented and bottom paint treated as hazmat materials.
Old copper paint on alot of boats.
Now with that being said, you can blast the lead keel as its in a sealed tent under the boat.
All paint must be cleaned up in sealed bags and disposed of proporly.
Wear your ppe
This is way we don't. Wet blast boats ...
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
The Following 2 Users Say Thank You to Dyer For This Useful Post:
hdavis (03-14-2015), M&RMMB (03-14-2015)
Old 03-14-2015, 06:35 AM   #12
MasterBlaster's Avatar
Trade: DUST FREE Media Blasting and Sandblasting
Rewards Points: 838
Re: Lead Keel
One other note, lead tends to oxidize rather quickly. You have to get a barrier coat on to it the same day of you're just wasting the customers money. Lead oxidation won't allow the paint to stick and the paint will just peel off once in water leaving one pissed off customer.
MasterBlaster is offline
The Following User Says Thank You to MasterBlaster For This Useful Post:
M&RMMB (03-14-2015)
Old 03-14-2015, 08:48 AM   #13
M&RMMB's Avatar
Rewards Points: 60
Re: Lead Keel
Thanks Guys. Officially the boat is at the homeowners house not sure if that changes things any?
M&RMMB is offline
Old 03-14-2015, 09:23 AM   #14
Dyer's Avatar
Rewards Points: 864
Re: Lead Keel
Needs to be treated as a lead job as does the bottom paint.
Your getting reimbursed for Services, makes it a hazmat job.
If the owner does it him self he can do it any way he wants to.
(take the lead class that Maine offers)
Boats need a complete tent under and around the boat. (encapsulate) to keep any media from getting out. (DEP and EPA rules)
I have tried many ways over the years, and boats are costly no mater how you do them. (yes wet, dry and hand prep...)
Dry is best, clean up wet sucks!
every state has about the same regs on boats, but they do change some.
Dyer is offline
The Following User Says Thank You to Dyer For This Useful Post:
M&RMMB (03-14-2015)
Old 03-14-2015, 10:23 AM   #15
hdavis's Avatar
Re: Lead Keel
Not really. You just don't have to worry about contaminating the ocean.
You really really should understand compliance before doing this.
M&RMMB (03-14-2015)
Old 03-14-2015, 06:03 PM   #16
Dyer's Avatar
Rewards Points: 864
Re: Lead Keel
I've been blasting boats for over 18 years and every boat yard does not want you to let materials
hit the ground. Most will not let you through the waste in their dumpsters.
the reg states that it must go to a clean landfill, which means it can go into a reg dumster. But not the boat yards.
doing it at someone's house, well if the neighbors call DEP, and there's a stream or wetlands near by, well get your check book out....
just saying.
all boat yards are only aloud to wash boats if they have a catch basin that will filter out waste.
Maine states that all boat paint should be handled as if it is hazardous material till disposed of properly
Dyer is offline
Old 03-14-2015, 06:27 PM   #17
hdavis's Avatar
Re: Lead Keel
just saying.
Yup, and if you powerwash, all the water gets collected before hitting the ground and filtered before the solids are disposed of and the water is disposed of. That's why I keep saying he needs to understand what he needs to do for compliance. As long as we're talking about Maine, our RRP laws are slightly different from Federal regs - more strict. The Federal guide says check with your state for disposal...
Dyer (03-14-2015)
Old 03-14-2015, 07:17 PM   #18
M&RMMB's Avatar
Rewards Points: 60
Re: Lead Keel
I definitely will be doing some reading on these guide lines before touching anything. They hold higher regulations for paint removal on marine over automotive typically? I'm guessing because different types of paint used? I'm still learning as I go with things here sorry guys. I'm looking to do things right and by the book that's for sure. Thanks for all your input.
M&RMMB is offline
Old 03-15-2015, 12:43 PM   #19
Dyer's Avatar
Rewards Points: 864
Re: Lead Keel
http://www.maine.gov/dep/land/watershed/marina/bmp.htm
www.maine.gov
search sandblasting boats
Dyer is offline
M&RMMB (03-15-2015)
Lead production companies PROJECTHR Online Leads Services 10 07-16-2016 04:46 PM
a perfect lead generation service? arafay Online Leads Services 2 05-08-2014 04:34 PM
EPA Backs Off Lab Testing for Lead greg24k General Discussion 3 09-28-2011 06:17 AM
EPA Drops Requirement for Third Party Testing on Lead Paint Removal Grumpy Lead RRP Discussion 2 07-26-2011 09:27 PM
