High Pressure Compressor - Sandblasting - Contractor Talk
Old 01-13-2016, 08:01 PM   #1
jm812003's Avatar
Trade: Sandblasting and painting
Rewards Points: 40
I just purchased a Sullivan palatek 375 high pressure unit to replace my pair of 185s, I am not set up for the high pressure with the rest of my blast equipment yet, can it be adjusted down to 120 on the Compressor instead of buying an expensive regulator? Also if I am running less pressure will it produce more then 375cfm?
jm812003 is offline
Old 01-13-2016, 08:34 PM   #2
BudgetBlast's Avatar
Trade: Blasting & Industrial Coatings
Rewards Points: 203
Re: High Pressure Compressor
I keyed the name and model of your compressor in to google and got this, it may help.
http://www.cipsa.com.mx/bo/file.php?id=3628
On one of the drawings there is a pressure regulator detailed so I assume the answer to your question is yes you can turn it down.
I have had hired in compressors with the regulator turned down by the hire company, presumably because they want to preserve the life of their machine.
Logically pressure and flow are directly related so less pressure should allow more flow but whether you have any control over this I have no idea. Regardless of the pressure you create the engine will be regulated in some way otherwise you will just ding the nuts off it.
Budget Blast Services
London UK
BudgetBlast is offline
Old 01-14-2016, 09:47 AM   #3
Ramrod, Troubleshooter
Bondo's Avatar
Trade: Blacktop,+ Dirt, along with about everything else
Rewards Points: 34
Ayuh,...... I'm confused,.... What are ya callin' high pressure,..??
In the linked manual, it runs at 125 psi, standard operatin' pressure of 100 psi,....
Same as every IR 185 I've ever worked on,.....
Bondo is offline
Old 01-14-2016, 10:21 AM   #4
jm812003's Avatar
Rewards Points: 40
This one makes 150psi. I would like to turn it down to 125 for now.
jm812003 is offline
Old 01-14-2016, 03:00 PM   #5
Bondo's Avatar
Rewards Points: 34
Ayuh,... Go for it, won't hurt a thing,.....
Sounds like a PO turned it Up, anyways,....
Bondo is offline
Old 01-15-2016, 09:21 PM   #6
Todd
blastserv's Avatar
Trade: media blasting
Rewards Points: 762
There should be a regulator hanging off the seperator (large round cylinder). It should have a handle or knob to adjust down.
Another way to lower the PSI is to stick a larger nozzle on it.
www.blastserv.com
blastserv is offline
Bad air from compressor Macm Sandblasting 6 12-14-2015 09:50 PM
High pressure nailers Sam-NZ Tools & Equipment 6 07-16-2015 08:27 AM
Question about workin on my own oil burner InterCounty HVAC 6 04-29-2013 12:05 AM
Opinions On Starting Out With A Gas Compressor sledhead54 Sandblasting 12 03-29-2013 06:17 PM
installing 250 cfm compressor into enclosed trailer JohnnysMB Sandblasting 44 12-31-2010 11:03 AM
