Crushed Glass Consumption - Sandblasting - Contractor Talk
Old 11-15-2014, 04:44 PM   #1
salty's Avatar
Trade: media blasting
Rewards Points: 126
Getting started on using crushed glass . We have been shooting only soda and walnut shells . What I have been reading is that I will be using five -six times the glass compared to what I normally shoot with soda ? About 2.5 -5 lbs per sq ft is this about right ? If that's right and with me doing the math it's still cheaper and faster than soda but a ton of media and a ton of clean up . Going to need a dump truck to dispose and haul away . What is anyone's thoughts on this .
I will be using a Empire 350 with a shmit metering valve 1" hose and a #5 nozzle . Thanks
salty is offline
Old 11-16-2014, 02:26 AM   #2
Bob
Sand Pot's Avatar
Trade: Abrasive blasting
Rewards Points: 886
Re: Crushed Glass Consumption
Where did you read that?
Sand Pot is offline
Old 11-16-2014, 05:35 AM   #3
salty's Avatar
Rewards Points: 126
Not sure I'll have to go back and look.
I think it was on one of the websites that was selling media . So maybe they are off on Their numbers ? With my soda pot turned up a blast about 1 lbs per min . Can anyone give me a ball park Figure on glass consumption per minute or per hour ?
salty is offline
Old 11-16-2014, 07:50 AM   #4
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
You know that's gonna vary all over the place but I have been able to get close to about half that or a little less most of the time depending on how course a grit. It will most likely work a little faster so the difference may not be so substantial but definitely not truck loads. What have you told the customers about leaving all the rust and darkened metal? I don't see how you can do most projects without an abrasive?
When it has to be clean, Betterblast it!
[email protected]
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 11-16-2014, 08:12 AM   #5
salty's Avatar
Rewards Points: 126
We mostly do Commercial building brick and stone work.
Getting into the glass after loosing my shirt on a mill job stripping
Paint with soda .
salty is offline
Crushed glass abrasive and abrasive blasting in Australia ausisoda Sandblasting 14 03-11-2017 09:58 AM
Stupid question? Anyone ever mix sodium bicarbonate with recycled glass? MasterBlaster Sandblasting 7 03-23-2013 06:14 PM
Crushed glass fillers, ? Dyer Sandblasting 19 03-22-2013 09:44 AM
Some Crushed Glass Info. painter213 Sandblasting 0 01-30-2012 01:06 PM
