Crushed Air/Oil Separator - Sandblasting - Contractor Talk
Thread Tools
Old 03-29-2015, 07:55 AM
Motivated Noob
BarrierIslands's Avatar
Trade: Abrasive Blasting
Rewards Points: 148
Well my Saturday was fun. What caused this?
Crushed Air/Oil Separator-unnamed.jpg
Barrier Islands Blasting LLC: Charleston, South Carolina
www.barrierislandsblasting.com
www.facebook.com/barrierislandsblasting
BarrierIslands is offline
Old 03-29-2015, 08:08 AM
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Re: Crushed Air/Oil Separator
Been there... Done that!
Check outwww.ecompressedair.com/
I found good prices for filters on there
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 03-29-2015, 08:12 AM
Motivated Noob
Rewards Points: 148
I already ordered a new one, should be here monday. I love Amazon Prime...
Any idea what causes this?
Old 03-29-2015, 08:14 AM
Dyer's Avatar
Rewards Points: 864
I couldn't Get answers from my IR dealer, but my thoughts...
Mine did it when starting my unit
The air has to has to be equal on both sides of the filter
Having a open valve somewhere on the line would cause a low on one side.
Now in cold weather, the opposite I do, cracking a valve little, so there is no load till the motor starts....
I went through 3 when I first got my unit. I haven't had one collapses for a long time.
I think too, if the filter has a dent in it that it would be a weak spot for it to hapoen
Dyer is offline
Old 03-29-2015, 11:05 AM
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Could be a sign of a bad unloader valve or your filter was restricted. As in needing replaced anyway. We've had it to happen before and usually was something to do with a unloader valve repair. The unloader valve is suppose to let the engine start without the strain of trying to build air or minimal air, and start at the same time.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 03-29-2015, 07:52 PM
Todd
blastserv's Avatar
Trade: media blasting
Rewards Points: 762
Foaming of screw oil can saturate filter. If this was the case and unloader stuck or unloader was loaded when cranking this could happen.
Was this the result of after a long run and a shut down for a short period then restart?
What was the circumstances?
www.blastserv.com
blastserv is offline
Old 04-01-2015, 04:30 PM
Motivated Noob
Rewards Points: 148
I accidentally ran the compressor out of fuel. After I refueled it and bled the injectors, it happened.
Old 04-01-2015, 04:32 PM
Motivated Noob
Rewards Points: 148
I got a new filter in today, however, I have a job in the morning and need fluid for the compressor. I was reading the manual and it says to use Sullair AWF fluid, D-A Torque Fluid, SAE10W Motor Oil, or MIL-L-2104E10W. If I was to go up to the parts store what is the best one I would be able to find? I attached a picture of the oil info for the compressor.
Crushed Air/Oil Separator-sullairoil.png
Old 04-01-2015, 04:56 PM
GettingBy's Avatar
Rewards Points: 6,486
Originally Posted by BarrierIslands View Post
What caused this?
Up to 14.7 pounds per square inch of atmospheric pressure on a surface that has many square inches?
I'm impressed!
The force required to unbend it will be greater because of work-hardening.
GettingBy is offline
Thread Tools
Rate This Thread
Crushed glass abrasive and abrasive blasting in Australia ausisoda Sandblasting 14 03-11-2017 09:58 AM
Crushed glass supplier in Europe? DIOXID.RO Sandblasting 4 04-04-2014 08:54 AM
Dry laid stone patio, Crushed 1A vs Sand NYCB Masonry 14 04-20-2013 09:35 PM
Crushed glass fillers, ? Dyer Sandblasting 19 03-22-2013 09:44 AM
Some Crushed Glass Info. painter213 Sandblasting 0 01-30-2012 01:06 PM
