Come On, Share Some Pictures Of Your Work... - Page 21 - Sandblasting - Contractor Talk
Old 11-05-2012, 07:02 PM   #401
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Re: Come On, Share Some Pictures Of Your Work...
48' trailer.
Lots of work on this sucker.
Come on, Share some pictures of your work...-image-4184190945.jpg   Come on, Share some pictures of your work...-image-2012639212.jpg
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 11-05-2012, 07:06 PM   #402
Dyer's Avatar
Rewards Points: 864
My helper cleaning up after blasting on a 1927 36' wooden boat
Used fine 30/60 glass
Came out real good, still needed some sanding on it but the bulk of it was off
Used 4 bags of glass, best usage yet
(Not typical though)
Dyer is offline
Old 11-21-2012, 02:49 PM   #403
Dyer's Avatar
Rewards Points: 864
Here is a small 25' push boat for moving barges around. Like a tug.
Took us 26 hours of blasting and 20 hours of paint.
We did the inside motor room floor too.
The cold weather only gave us a small window to blast and prime before Droping below 30 at night.
Come on, Share some pictures of your work...-image-1712921022.jpg   Come on, Share some pictures of your work...-image-776900824.jpg   Come on, Share some pictures of your work...-image-2863150597.jpg
Dyer is offline
The Following User Says Thank You to Dyer For This Useful Post:
Cuda (11-21-2012)
Old 11-26-2012, 12:16 AM   #404
BlasterJim's Avatar
Trade: Specialty Coatings
Rewards Points: 16
MasterBlaster how many hrs did this patio/pool deck take with your geoblaster?
After
BlasterJim is offline
Old 11-26-2012, 05:44 AM   #405
MasterBlaster's Avatar
Trade: DUST FREE Media Blasting and Sandblasting
Rewards Points: 838
That job took us 1 to 2 hours for prep, 4 to 5 hours of blasting and between 1 to 2 ours for clean up.... pools are difficult because you have to put plastic over them.
With stamped concrete you also have to be very gentle or you'll blow right through to the aggregate.
MasterBlaster is offline
Old 11-26-2012, 06:53 AM   #406
ausisoda's Avatar
Trade: abrassive blasting
Where was that blasted dyer close to town?
Looks like a lot of containment.
ABSS supplies.
For a bullet proof blasting machine made in Australia they should be your first choice.
They produce top quality equipment that will give you hours of trouble free blasting.
Their customer service is the best in the business.
ausisoda is offline
Old 11-26-2012, 10:18 AM   #407
Dyer's Avatar
Rewards Points: 864
Contained the bottom because of the old bottom paint.
The job was just out if town. 30 min from our house. Nice job but forgot about cold weather when I priced it out.
Forgot ya can't blast 10 hours and paint when you only have a 7 hour window for both.
5 days turned into 9. But that ok we still made out good.
Dyer is offline
Old 11-27-2012, 06:05 PM   #408
Rewards Points: 838
Here are a couple of jobs we did over the past week of so.
This one is an old Agway grain building that was being converted into high-end office space.
The building had all the exterior walls removed other than the silo.
And yes those are grain silos on the right and each one is being converted into a circular office 4 on each floor.
This is the inside of the third floor... we were brought in to blast all the old structual steel which was all rusty.
Here you can see the steel we blasted below and the rusty stuff above.
This is the second floor again the steel we blasted and a some we still had to do.
Cool project we did on two weekends while construction folks were off.
The Following User Says Thank You to MasterBlaster For This Useful Post:
Cuda (11-27-2012)
Old 11-27-2012, 06:10 PM   #409
Rewards Points: 838
Here's another job we knocked out this week... these are work lifts for mechanics who work on goverment aircraft.
These things are Airforce gray rusty and beat up... kind of hard to blast them considering both the metal and paint is gray with no primer between.
Here's one we blasted... 92 more to do.
Old 11-27-2012, 06:14 PM   #410
Rewards Points: 838
Two boats we just pumped out of the shop this past Friday.
Pair of Parkers 28' and 25' before we GeoBlated blasted them.
Pair of Parkers 28' and 25' after we GeoBlated blasted them.
Pair of Parkers 28' and 25' after we put SeaHawk Tuff Stuff barrier epoxy on.
Pair of Parkers 28' and 25' after we put SeaHawk Cukote multi Seasonal ablative paint on.
Was in Milford Delaware this past weekend doing a 30 Boston Whaler.
Old 11-27-2012, 08:52 PM   #411
Cuda's Avatar
Trade: Drainage, Waterproofing & Sewer Contractor
Rewards Points: 214
I like that conversion to office space! Neat job!
Cuda is offline
Old 11-28-2012, 01:18 AM   #412
ausisoda's Avatar
How long to blast the lifts?
ABSS supplies.
ausisoda is offline
Old 11-28-2012, 05:16 AM   #413
Rewards Points: 838
5.5 hours on the one that looks like the lunar lander.
4 hours on the one with steps
The lunar lander was tough because the thin poles had to be hit from three different directions and the top section had to be pumped up another 5 feet to blast everything under it.
Somewhat of a pain in the butt, because every time you thought you were done you'd find more paint you missed.
Anyway 92 more these coming so it's a nice filler job back at the shop for winter blasting.
Old 11-28-2012, 05:32 AM   #414
ausisoda's Avatar
Stuff like that is a pain due to all the angles.
I was guessing around the 4 hour mark.
They came up nice.
I have some big diesel tanks to do tomorrow that won't be getting done due to it being 44 degrees C here tomorrow.
only early morning blasting for the next 4 months.
ABSS supplies.
ausisoda is offline
Old 12-02-2012, 11:06 AM   #415
any media master blaster
wesschaff's Avatar
Trade: sand blastiing
Rewards Points: 158
Just finished this 60k ft depainting of a large pool using a combination of Wet Blasting and Blastpro Shot blasting.
We are now marketing wet blast conversion kits for dry blast pots call 973 885 8036 for details.
Wes
www.green-surface-solutions.com
wesschaff is offline
Old 12-07-2012, 04:20 PM   #416
70scorpion's Avatar
Trade: surface preparation/restoration
Just joined forum and wanted to introduce myself.
Here is a couple pics of a gooseneck trailer I did a month or so ago.
Painter was on standby to get a coat of primer on before rust set.
Come on, Share some pictures of your work...-img_0039.jpg   Come on, Share some pictures of your work...-img_0028.jpg   Come on, Share some pictures of your work...-img_0037.jpg
70scorpion is offline
Old 12-11-2012, 07:44 AM   #417
Rewards Points: 838
Here's a Corvette we did back in October with the GeoBlaster.
Corvette stripped and on stand before we GeoBlasted it.
Corvette stripped and on stand after we GeoBlasted it.
Good Stuff!
Old 12-11-2012, 09:18 AM   #418
Rewards Points: 838
Here's one we just rapped up last Friday.
62 cast iron radiators all between 4' and 8' in size.
In this case we dry blasted them, because of the outside temperatures
5 pallets of 40 50lbs bags of medium/course recycled glass.
If we wet abrasive blasted these it would have been just one pallet of glass plus maybe 10 gallons of hold-blast.
Anyway all good stuff!
This was what we were called in to do... a trailer full of 62+ radiator for a historic facility undergoing a major renovation.
This is pretty much what all the radiators looked like in the trailer.
Here's a close up... as you can see these are the 5 cell type radiators making it hard to blast in between all the cells.
The client designated an area that was out of the way and in this case we set up a containment tent where all the blasting took place.
The radiators where moved in and out of the containment tent in groups of 6 and 8 at a time.
Pretty simple, take the radiators off the pallet and lay them on top of one another... blast one side and then tumble it over and blast side as well as the face of the other radiator... then tumble them back into the pile and clean blast with air.
Clean blasted radiators come out and the lift made things easier.
This is pretty much what all the 62 radiators looked like when we were done.
KramerInd (12-12-2012)
Old 12-16-2012, 05:04 AM   #419
ausisoda's Avatar
Did a lifting crane today.
Blast time 2 hours.
ABSS supplies.
ausisoda is offline
Old 12-16-2012, 06:19 AM   #420
Rewards Points: 838
Blast time 2 hours.
Nice!
What media were you using on this one Ausi?
I am not intitled to show pictures of my work Mark Daniels Marketing & Sales 41 09-02-2012 11:04 AM
High Horses and "Ironing Boards" for Detail Work basswood Finish Carpentry 47 06-15-2010 06:31 PM
Pictures of poor work/ sales proposals J-Peffer Roofing 15 05-10-2009 07:22 PM
In answer to a closed thread. AAPaint donb1959 Painting & Finish Work 42 08-27-2006 12:36 AM
