Come On, Share Some Pictures Of Your Work... - Page 15 - Sandblasting - Contractor Talk
Old 06-10-2012, 09:03 AM   #281
coatingsguy's Avatar
Trade: Coatings Sales/Service & Media Blasting
Rewards Points: 85
Re: Come On, Share Some Pictures Of Your Work...
there was a lot of metal on this old car... almost 8 hours of blast time...7 bags of fine glass...
Come on, Share some pictures of your work...-46-before.jpg   Come on, Share some pictures of your work...-46-during.jpg
coatingsguy is offline
Old 06-12-2012, 07:22 PM   #282
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
Nitrogen Trailer blasted with fine glass
Got this job because the other guy wasn't showing up on time when he said or giving a bill on a timely bases. It's all about the PR
Job took longer than we thought
16 hours complete blast
Come on, Share some pictures of your work...-image-864960727.jpg   Come on, Share some pictures of your work...-image-4158967967.jpg   Come on, Share some pictures of your work...-image-746963613.jpg
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
The Following User Says Thank You to Dyer For This Useful Post:
MALCO.New.York (07-16-2012)
Old 06-12-2012, 07:58 PM   #283
Rewards Points: 85
nice work jim........
The Following User Says Thank You to coatingsguy For This Useful Post:
Dyer (06-13-2012)
Old 06-13-2012, 04:59 AM   #284
ausisoda's Avatar
Trade: abrassive blasting
Thats what I call white metal clean.
Looks great.
ABSS supplies.
For a bullet proof blasting machine made in Australia they should be your first choice.
They produce top quality equipment that will give you hours of trouble free blasting.
Their customer service is the best in the business.
ausisoda is offline
The Following User Says Thank You to ausisoda For This Useful Post:
Dyer (06-13-2012)
Old 06-13-2012, 05:42 AM   #285
Dyer's Avatar
Rewards Points: 864
Took longer than I thought, the humidity was giving us problems
3 water traps were cracked open and two fans running on the dryers And still was getting blue flame. Made the fine glass run like crap too.
Had to keep stoping to get the grit to slide down in pot.
Over all it looked great in the end, and it's going into a heated paint booth at the customers place.
The fine glass is slower to blast with, but sells itself in the end!
The Finnish is clean... The painter has less work to do... And you can get right next to lines without cutting them up.
Got my foot it the door with this guy, all he does is work on trucks and trailers, open 24 hours a day. Does lots of work. Took a beating on the price, self inflicted. But if there's more work I'll make it up.
I was lucky there was no rust on the truck, just heavy epoxy paint.
Got good stats for my records for the next trailer.
Dyer is offline
Old 06-13-2012, 05:47 AM   #286
Dyer's Avatar
Rewards Points: 864
P.S. I now wish after buying my 260 cfm ingersoll compressor that I had bought the 150 high pressure one...
That little bit more psi would have done better on the heavy coatings
Dyer is offline
Old 06-13-2012, 05:57 AM   #287
ausisoda's Avatar
Dyer have you thought about using the course grade grit.
I use a mix now that is fantastic it has .8mm mixed with the fine.
The courser stuff in the mix cuts quicker and the fine gets it to white metal it's the best of both worlds.
Either that or I just use the course stuff that is 1.5mm it works great on heavy coatings.
I do a lot of chlorinated rubber based paint and the course stuff eats it for breakfast.
The course glass for thick coating removal cannot be beat.
I have tried GMA garnet on that stuff and the glass works 3X better.
ABSS supplies.
ausisoda is offline
Old 06-13-2012, 06:01 AM   #288
ausisoda's Avatar
Have you cleaned the inside of your cooler a few hidden PSI can be found after a good clean.
That big red one I posted a pic of a while ago would not give me over 90psi at the pot when blasting.
I filled it with Kerosene and let it sit for a couple of days then flushed it with a mild caustic solution and I now get 120psi at the pot while blasting.
ABSS supplies.
ausisoda is offline
Dyer (06-13-2012)
Old 06-13-2012, 06:03 AM   #289
Dyer's Avatar
Rewards Points: 864
Ya we have used the course a lot, just find that if I'm not painting it, the customer sees it as still looking dirty.
We switched to the fine a year or two back, with great feed back from our customers.
I give them a choice before starting, explaining the difference and most want to pay a little more to have it clean...?
With this guy I will got corse on some of the trailers just because there big and good looks don't matter.
The Nitrogen cart goes to hospitals and had to look really good.
Dyer is offline
Old 06-13-2012, 06:06 AM   #290
Dyer's Avatar
Rewards Points: 864
Good idea Ausi, I blow air through the out side all the time.
Never gave it a thought to flush the inside!
thanks!
Plus it's all plumbed with 1". Think I'm going to plum all pipes from compress to the blast pot with 1-1/2 pipe to get max cfm to the pot.
Just need the time to do it.....lol
Dyer is offline
Old 06-17-2012, 10:52 PM   #291
ccogan05's Avatar
Trade: Sand Blasting
Rewards Points: 25
some stuff i did this weekend.
68 mustang fast back
front door
did this a few weeks ago
70s studabaker avanti fiberglass car
ccogan05 is offline
Old 06-18-2012, 11:52 AM   #292
Rewards Points: 85
fun little car, but a lot of filler and paint...1963-356 b
Old 06-18-2012, 11:55 AM   #293
Rewards Points: 85
forgot this one... so glad the customer didnt want all the filler out
Old 06-25-2012, 08:23 PM   #294
Kelly
kell490's Avatar
Trade: Media blasting
Rewards Points: 254
First time using New Age media they just opened a plant in the west great stuff. Trivetro 70grit is what I have been using for 3 years but the medium New Age cuts faster it's less forgiving you can etch the metal if you aren't careful where the trivetro was really idiot proof I would rather have a faster cutting glass and a little more training for my guy doing the blasting. We only used 10 bags to blast the outside and door jams.
50 PSI #5 Schmidt long nozzle Medium 40/70 New Age Crushed Glass
+ YouTube Video
+ YouTube Video
kell490 is offline
Old 06-26-2012, 07:16 AM   #295
Dyer's Avatar
Rewards Points: 864
Wood Chipper Blasted & Painted for a City in Maine
Blasting just took over 2 hrs
(Blasted to white, fine glass, not the motor)
we put ZRC Cold Galv as a base coat to stop rust
then used a Sherwin-Williams
High Soild Polyurathane industrial as a top coat
Come on, Share some pictures of your work...-lewiston-pw-2.jpg   Come on, Share some pictures of your work...-lewiston-pw-4.jpg   Come on, Share some pictures of your work...-lewiston-pw.jpg   Come on, Share some pictures of your work...-lewiston-pw-3.jpg
Dyer is offline
The Following 2 Users Say Thank You to Dyer For This Useful Post:
MALCO.New.York (06-28-2012), PlasmaGuy (06-28-2012)
Old 06-29-2012, 09:07 AM   #296
SD DMB's Avatar
Trade: Media Blasting
Rewards Points: 25
1978 El Camino done with fine crushed light bulbs
1954 Chevy pickup, entire truck was the project, inside and out, frame, fenders box the works. All with crushed light bulbs
www.dakotamediablasting.com
SD DMB is offline
Old 07-02-2012, 08:49 PM   #297
GeoBlaster's Avatar
Trade: Wet Abrasive Blasting Contractor
Blast Media Used: Enviro-Grit 50/100 Glass Abrasive
Blast Pressure: 70 PSI
Compressor Used: 185 CFM
Blast Time: Approximately 3.5 Hours (including inside trunk)
Nozzle Size: #6
Approximate Media Used: 8 - 50 lb. bags
Approximate Fuel Costs: $25.00
Approximate Water Usage: 80 Gallons
GeoBlaster is offline
Old 07-02-2012, 10:16 PM   #298
ausisoda's Avatar
Where is ya Respirator?
Still looked dusty.
ABSS supplies.
ausisoda is offline
Old 07-03-2012, 04:39 AM   #299
ausisoda's Avatar
I have 136 of these to do.
Thick chlorinated rubber coating insides only.
Each bin takes 20mins so 3 an hour charging $80 per bin.
No7 bazooka nozzle.
[email protected]
Brush blasted to remove coating ready to apply surface tolerant epoxy coating.
ABSS supplies.
ausisoda is offline
Old 07-03-2012, 04:44 AM   #300
ausisoda's Avatar
Here is my rig on site.
She's basic but I get problem free blasting.
This morning it was 0 degrees and water was running down the sides of my after cooler the condensation in the air was that bad I didn't miss a beat.
ABSS supplies.
ausisoda is offline
I am not intitled to show pictures of my work Mark Daniels Marketing & Sales 41 09-02-2012 11:04 AM
High Horses and "Ironing Boards" for Detail Work basswood Finish Carpentry 47 06-15-2010 06:31 PM
Pictures of poor work/ sales proposals J-Peffer Roofing 15 05-10-2009 07:22 PM
In answer to a closed thread. AAPaint donb1959 Painting & Finish Work 42 08-27-2006 12:36 AM
