Clear Coating Question (High Temp)? - Sandblasting - Contractor Talk
Old 01-16-2013, 09:57 PM   #1
MasterBlaster's Avatar
Trade: DUST FREE Media Blasting and Sandblasting
Rewards Points: 838
Hey guys, I'm somewhat stumped on this one...
I picked up a bunch of radiators in Princeton NJ that the client wants blasted and clear coated so they have that industrial look.
I've contacted just about every paint company out there and have been told a bunch of crazy things that might work, but no one will guarantee their product will work of last.
Also from what I can tell is the coating has to hold up to a max temp of 210
The only thing that I've come across that might work is clear engine enamel, only problem is it only comes in 12 oz and 16 oz aerosol cans and I'd like to buy it by the quart or gallon if possible.
Anyone have any other idea on a clear coat that will work at 210?
Thanks
Dale
MasterBlaster is offline
Old 01-16-2013, 11:01 PM   #2
any media master blaster
wesschaff's Avatar
Trade: sand blastiing
Rewards Points: 158
Re: Clear Coating Question (High Temp)?
Hey Dale,
Use minwax satin polyurethane add silver or gold to tint it, make sure to use the solvent type .
Wes
www.green-surface-solutions.com
wesschaff is offline
Old 01-17-2013, 07:01 AM   #3
Rewards Points: 838
Originally Posted by wesschaff View Post
Hey Dale,
There's nothing on the msds sheet that says it holds up to heat and won't yellow.
Old 01-17-2013, 07:35 AM   #4
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
DiamondFinish ClearCoat is able to perform in the high temperature automotive applications including the use on cylinder heads, engine blocks, brake components and even inlet manifolds, without yellowing up to 325 Fahrenheit.
An incredibly tough and hard ClearCoat like no other on the market. This water clear high gloss clear coat remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
Pint - $34.95 | Quart - $49.95
Gallon - $184.95 | 5 Gallon - $749.95
Your Price:$184.95
Only $9.95 Shipping per order.Size: Size Pint Quart Gallon 5 Gallon Pail Color: Color Clear - High Gloss QuantityUsually Ships Same Business Day. +More Info</div>
When it has to be clean, Betterblast it!
[email protected]
P-610-323-8084
http://betterblast.com/
Betterblast is offline
The Following 2 Users Say Thank You to Betterblast For This Useful Post:
MasterBlaster (01-17-2013), PlasmaGuy (01-17-2013)
Question about GL and Marketing your business? CJ21 Business 0 10-04-2012 09:48 AM
trivia quick framing question acarpentertx Framing 24 09-30-2012 10:54 AM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 07:48 AM
Price too high! Mike Finley Marketing & Sales 45 01-16-2010 09:12 PM
Question About Skim Coating Process plazaman Drywall 10 06-29-2006 12:10 AM
