Blasting Handrails - Page 2 - Sandblasting - Contractor Talk
Blasting Handrails
Old 05-02-2015, 08:01 PM   #21
nonobadog's Avatar
Trade: media blasting
Rewards Points: 328
Re: Blasting Handrails
Salty,
I noticed you said it is on the water. I don't know about your area, but here if you are shooting over the water you need a permit. I passed up a job cleaning up a handrail over the water. The general contractor refused to get a permit or allow me to get one. EPA will fine you big time. On Holmes Harbor, the fine would have been about $10,000.
Be sure you check it out and do not trust the customer. They tend to bend the truth when it will save them money.
nonobadog is offline
The Following User Says Thank You to nonobadog For This Useful Post:
salty (05-02-2015)
Old 05-05-2015, 06:42 PM   #22
salty's Avatar
Rewards Points: 126
Looking at all my options I think the only way to do this job is renting a vacuum blaster . What I have seen and read looks like they are slow but no mess and can recycle garnet . Any thoughts painter ?
salty is offline
Old 05-05-2015, 08:07 PM   #23
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
How about removing the handrails, taking them to a shop, blast, paint, and reinstall? Vacuum blasting will be slow, and if you do not have the CFM's, will not work.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 05-05-2015, 08:10 PM   #24
salty's Avatar
Rewards Points: 126
You think I would need more than 210 CFM ? Removing them cannot be done I was told
salty is offline
Old 05-05-2015, 09:42 PM   #25
painter213's Avatar
Vacuum blasting is going to require about double the CFM. This is due to you need the air for driving the abrasive blaster and the vacuum for the system. Your having to pull as much air or more than what your blasting with so to have a negative chamber for vacuum blasting. I would look at having them removed. Might cost more, but probably actually cheaper in the long run.
[email protected]
205-717-0292
Old 05-05-2015, 09:42 PM   #26
painter213's Avatar
But, I also haven't seen the job site either.
[email protected]
205-717-0292
The Following User Says Thank You to painter213 For This Useful Post:
salty (05-05-2015)
Need Blasting Equipment AND advice.... fishwich2005 Sandblasting 4 09-02-2014 08:54 PM
Bridge Blasting ccogan05 Sandblasting 24 04-07-2014 09:13 AM
Dustless Blasting. Info please Dyer Sandblasting 19 10-16-2013 06:18 AM
Dry Ice Blasting Tour Sept 14-17 KevinIceTech General Discussion 0 08-16-2010 10:07 AM
Dry Ice Blasting Tour Sept 14-17 KevinIceTech Tools & Equipment 0 08-16-2010 09:57 AM
