Blasting Handrails - Sandblasting - Contractor Talk
Blasting Handrails
Old 05-01-2015, 05:29 PM   #1
salty's Avatar
Trade: media blasting
Rewards Points: 126
Blasting Handrails
Need help on how I should charge for blasting 2 " handrails . Never have blasted anything round I hear it's a pain . My question is should I charge by the hour or by the linear ft ? Also have to think about clean up and maybe using a small blast tent .Any thoughts on price or time per ft or how much could be done per hour would be great . Using a Empire 350 #5 nozzle with 210 cfm unit . A around 1300 hundred ft of hand rail with two rails 2" wide Thanks
salty is offline
Old 05-01-2015, 10:23 PM   #2
mnc516's Avatar
Trade: Log Restoratuion
Re: Blasting Handrails
I do a lot of rails and yes, they suck. I figure them by the square ft (diameter x Pi x length) and then use my Sq ft pricing. I still do better than by the hour, but it's a lot of messing around. I've made tarp back drops to catch the overspray. I also use a #5 nozzle and fine glasa. Hope this helps!
mnc516 is offline
The Following User Says Thank You to mnc516 For This Useful Post:
salty (05-05-2015)
Old 05-01-2015, 10:44 PM   #3
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Estimate handrails as a solid surface times 2.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 05-02-2015, 12:35 AM   #4
salty's Avatar
Rewards Points: 126
Ok thanks guys !! So measure all pipe then then x 2 of what my square ft price is ??
salty is offline
Old 05-02-2015, 12:43 AM   #5
salty's Avatar
Rewards Points: 126
516 what is PI ?? Sorry
salty is offline
Old 05-02-2015, 01:26 AM   #6
salty's Avatar
Rewards Points: 126
I got it 516 had to Go back to school
salty is offline
Old 05-02-2015, 02:22 AM   #7
salty's Avatar
Rewards Points: 126
You guys think I could do 15 ft hr upper and lower 2 in rails
salty is offline
Old 05-02-2015, 06:50 AM   #8
painter213's Avatar
That's not what I said. Measure the handrail space as a solid as though it was a solid wall and times it by two. So if your handrails are 36" tall and 100' long your surface area would be 36"x100'= 300sq.ft x 2 = 600sq.ft
[email protected]
205-717-0292
Old 05-02-2015, 11:26 AM   #9
salty's Avatar
Rewards Points: 126
This is an upper and lower railing. No spindles, no fencing. 2" dia x 1300' length. By your math it's 8164sqft of 'round' surface area. Am I following correctly?
salty is offline
Old 05-02-2015, 12:25 PM   #10
painter213's Avatar
Again, your not taking the footage of the pipe itself, but of the whole surface area of the handrail. Space between the rails. Estimate it as if it was a solid wall with two sides.
[email protected]
205-717-0292
Old 05-02-2015, 12:40 PM   #11
salty's Avatar
Rewards Points: 126
Ok I got it thank you . I think this is going to be a big job . It would be nice if I could do a 100 ft a day !
salty is offline
Old 05-02-2015, 01:12 PM   #12
painter213's Avatar
You should be able to. What degree of blast are they looking for? #7, #6, #10 or #5?
[email protected]
205-717-0292
Old 05-02-2015, 01:21 PM   #13
salty's Avatar
Rewards Points: 126
Think # 5
salty is offline
Old 05-02-2015, 01:22 PM   #14
salty's Avatar
Rewards Points: 126
Well I take that back they are welding on plates between rails . It on the water
salty is offline
Old 05-02-2015, 01:34 PM   #15
painter213's Avatar
There wanting a white metal blast on handrails? That's almost unheard of. What type of an environment are they in?
[email protected]
205-717-0292
Old 05-02-2015, 01:36 PM   #16
painter213's Avatar
Normally in a atmospheric service a #6 commercial blast is perfect. Also, what kind of a paint system is being applied? Zinc, Epoxy, Urethane? Or just a normal oil base alkyd?
[email protected]
205-717-0292
Old 05-02-2015, 01:54 PM   #17
salty's Avatar
Rewards Points: 126
Not sure of the paint .
salty is offline
Old 05-02-2015, 02:06 PM   #18
painter213's Avatar
Generally that is what dictates the needed degree of blast for any structure. If they are requiring a #5 White Metal Blast, then you'll need to figure for a lot of time and abrasive. That is the best of the best of abrasive blast cleaning and no staining is allowed. Here is a simple
visual chart to compare. This is with Grade D steel.
[email protected]
205-717-0292
Old 05-02-2015, 02:14 PM   #19
salty's Avatar
Rewards Points: 126
Wow ok this is good to know thank you . I was off on the Classifications . Iam Pricing the job using glass 30/60
Would you recommend another media ?
salty is offline
Old 05-02-2015, 02:54 PM   #20
painter213's Avatar
Depends on what coating system is being applied, but 30/60 glass should be fine. Should give you a 2-2.5 mil profile.
[email protected]
205-717-0292
The Following User Says Thank You to painter213 For This Useful Post:
salty (05-02-2015)
Need Blasting Equipment AND advice.... fishwich2005 Sandblasting 4 09-02-2014 08:54 PM
Bridge Blasting ccogan05 Sandblasting 24 04-07-2014 09:13 AM
Dustless Blasting. Info please Dyer Sandblasting 19 10-16-2013 06:18 AM
Dry Ice Blasting Tour Sept 14-17 KevinIceTech General Discussion 0 08-16-2010 10:07 AM
Dry Ice Blasting Tour Sept 14-17 KevinIceTech Tools & Equipment 0 08-16-2010 09:57 AM
