Blast Pool Plaster. Advice?? - Sandblasting - Contractor Talk
Old 04-16-2015, 03:50 PM   #1
79lance's Avatar
Trade: Sandblasting/Wood flooring
Rewards Points: 24
Since all of a sudden i have found myself out of the oilfield blasting and into pool blasting somehow lately, i need some info from people that have done pools before. Im looking at a pool of about 1,550 sq ft, and they want the plaster removed as well. I only have about 100' of line, and need another 50' of line, 50' deadman hose, and another 100' of respirator hose. I have a 185 Sullair on my mobile, and am probably going to have to rent a 375 Sullair to keep pressure up with that much hose. So questions:
What do you recommend me use to blast with? my usual #4 sand will probably be way to slow i would think?
I know prices vary depending on locations, but what would you price this at, or how do you figure your pools?
How long has pools of this size took you before or how long do you think it would take?
Im going to spend about $1000 just in new hoses and compressor rental already, but just not sure what to use or how to even come up with an estimate. ya'lls advice is greatly appreciated!
79lance is offline
Old 04-16-2015, 04:41 PM   #2
painter213's Avatar
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Re: Blast Pool Plaster. Advice??
I would never try to remove the plaster by blasting man. Get you some Pneumatic tile spades with 3" wide chisels and go to town. Much easier and faster. I've done several this way years ago. After the plaster is off then give the gunite a good sweep blast.
NACE Certified Coatings Inspector Level III #7953
SSPC Protective Coatings Specialist #2014-529-139
[email protected]
205-717-0292
painter213 is offline
Old 04-16-2015, 07:53 PM   #3
79lance's Avatar
Rewards Points: 24
interesting. makes sense. might have to hire me a few guys and put em to it haha
79lance is offline
Old 04-16-2015, 10:23 PM   #4
painter213's Avatar
That's what I would do. Once you get through it with the chisels it just comes off easy most times. We used the Pneumatic tile spades and then the straight bore air chisels for removal of the plaster from the pools. Trying to blast it off can be done, but it's slow and your just going to have a lot more waste to have to haul off.
[email protected]
205-717-0292
Old 04-19-2015, 10:28 AM   #5
Glen
Betterblast's Avatar
Trade: Media blasting
Rewards Points: 686
Certainly agree with that. Same as when they remove plaster from a stone farm house and then call me in to clean it up.
Personally I would use longer and less expensive air hoes and just bring the pot close enough or even down in with you. You don't want to drag a 150' blast hose full of media.
When it has to be clean, Betterblast it!
[email protected]
P-610-323-8084
http://betterblast.com/
Betterblast is offline
Old 04-19-2015, 02:39 PM   #6
nonobadog's Avatar
Trade: media blasting
Rewards Points: 342
I shot a pool recently. I had to be careful not to take too much plaster off. In a couple of places the plaster almost fell off. Still, the chisels are the way to go if you are going to remove the plaster. It will be faster, less cost for you.
Definitely use longer air hose and less blast hose. I did not need to put the pot in the pool. I used #70 vitro grit and about 60psi at the blast line. I used a #6 fan nozzle.
The customer did the disposal and it was not considered hazardous, push broom, scoop shovels and 5gal buckets to a dump trailer.
nonobadog is offline
Old 04-20-2015, 10:04 PM   #7
Bob
Sand Pot's Avatar
Trade: Abrasive blasting
Rewards Points: 886
nono where are you getting your Vitro? The price on that stuff seems to have gone up quite a bit recently where I am getting it
Sand Pot is offline
Old 04-21-2015, 12:12 PM   #8
nonobadog's Avatar
Rewards Points: 342
Yeah it has. I get it from united supply in south Seattle 206 767 9880. I don't have a contact person since Gail left.
I talked to them last fall and they said vitro had to double the price to stay in business. Then a couple months later they went out of business anyway.
They are getting glass from somewhere in Canada now. The price is still high. They say it is cleaner than vitro was because the Canadians take rinsing before recycling more serious than we do. They are trying to get the price down but I'm not gonna be turning blue.
Old 04-21-2015, 06:17 PM   #9
Bob
Sand Pot's Avatar
Rewards Points: 886
OK, that squares with they told me too. I've started getting glass in Tacoma at Kleen Blast, apparently it is coming out of a bottle recycler in Idaho. I've had two loads, its OK stuff and buying a skid of 40 bags or more the price is about same as where we both were buying it.
Whoops, sorry for the thread hijack 79lance
Sand Pot is offline
Old 04-25-2015, 11:57 PM   #10
Roadoil's Avatar
Trade: Environmental Service
Rewards Points: 96
Removing down to plaster prob $3.00 sq foot or more
Roadoil is offline
Family member wants me to supervise pool reno.. couple questions for ya DCRocks Pool Construction & Enclosures 3 11-11-2014 06:57 AM
blasting pool with clean blast aka coperslag kauai88 Sandblasting 0 10-16-2014 11:39 AM
Im bidding for a commercial painting job. any advice? BaranG Painting & Finish Work 13 02-25-2014 01:54 AM
Venetian Plaster Glossary Plaster Ayn Faux Finishes 3 04-27-2011 08:46 AM
I need help how to blast a pool Blastzone Sandblasting 20 03-25-2010 05:42 PM
