Anyone Using A Diesel Compressor At Their Shop? - Sandblasting - Contractor Talk
Old 06-08-2013, 08:37 PM   #1
Blast Off's Avatar
Trade: Media Blasting
Rewards Points: 275
Question
Is it parked inside or outside?
I don't have 3 phase power available but have Michigan winters to deal with.
Blast Off is offline
Old 06-09-2013, 02:54 AM   #2
RoKa.ARG's Avatar
Trade: Sand Blasting
Rewards Points: 18
Re: Anyone Using A Diesel Compressor At Their Shop?
yeah, it is parked outside (i have locks on the inspection doors). in winter time i try to park it inside, but only if i have room for it
RoKa.ARG is offline
Old 06-09-2013, 06:38 AM   #3
Trial and Error Opperator
Dyer's Avatar
Trade: SandBlasting/Soda Blasting
Rewards Points: 864
YUP! i DO
I ONLY HAVE A 30' X 30' SHOP
When I blast stuff, i have it next to the shop and run the hoses
through a little trap door on the side.
when nothings in the shop, I put it in there.
Running it in the shop? only if you can get the exhaust out side and some way to get fresh air in to it.
I live out in the boondocks and don't have 3 phase either. ..
love to get a electric air compressor for the shop, but some of us have to live like were are on the walking dead...
It's one persons stuppid question; that many want to know the answer to.
Web Site: www.DyerSodaBlasting.com
Email: [email protected]
Facebook:https://www.facebook.com/dyers.sodablasting
Dyer is offline
Old 06-10-2013, 08:28 PM   #4
SD DMB's Avatar
Rewards Points: 25
Same here, just like Dyer, outside when it's warm, otherwise mine tends to shut down due to high heat if it's inside, winter time it's inside...a 185 compressor going when it's -20 degrees, makes it about 85 inside my shop, no heat on, garage doors wide open, working in a t shirt and jeans all winter long!!!
www.dakotamediablasting.com
SD DMB is offline
Old 06-10-2013, 09:01 PM   #5
Blast Off's Avatar
Rewards Points: 275
Dakota,
Do you do anything else besides pipe the exhaust outside? How big is your shop?
I would like to run my 375 inside but will probably need to push it outside in the morning to run and back in at night.
Old 06-11-2013, 11:15 AM   #6
SD DMB's Avatar
Rewards Points: 25
With my doors open and the machines fan I haven't had a problem. Shop is 2200 sq feet so my machines on the opposite end of where I'm working
SD DMB is offline
Old 06-11-2013, 02:48 PM   #7
Dyer's Avatar
Rewards Points: 864
They sell a Rubber hose that is for high heat exhaust.
fire dept use them to start the trucks in the garages before heading out
Sorry dont know were to get them, but do know there BIG $$$
my shop is 30 x 30 with a wall down the middle (and a door for entry)
I bast on one side and its sealed shut anyway the other side is the "clean side" kind of
i had a pipe from the last job that was high heat, I would stick it on the exhaust and out to a old fan (metal) that would help pull the fumes out.
With the door up it still was 70 deg in the winter with the air off the motor.
with my new compressor, its on the trailer and don't fit into the garage, plus the pipe had feet and despaired to a new home..
so i run it out side, even in the winter.
Dyer is offline
Shop Facelift cranbrook2 Carpentry Picture Post 8 08-14-2012 08:36 PM
Shop built receiver-dryer PlasmaGuy Sandblasting 16 08-09-2012 10:59 AM
Setting Up a Shop GRB Tools & Equipment 42 08-05-2012 10:19 PM
Wanna help me design my new shop? pinwheel General Discussion 6 02-13-2011 05:06 PM
My new shop . deadjed General Discussion 17 12-30-2010 08:21 PM
