Mobile Sandblasting
Trade: SANDBLASTING
Rewards Points: 554
Anyone Ever Made There Own Hold Tight/Blast Hold?
I was just thinking on how difficult it would be to make your own holdtight or blasthold liquid spray in a yard sprayer. I know pH has a lot to do with it, it would just be nice to be able to have your own recipe for when you need those extra few days. Does anybody have any recipes for this, or is it best just to go by the product.
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
Trade: Media Blasting
Rewards Points: 275
Re: Anyone Ever Made There Own Hold Tight/Blast Hold?
Old school body shop guys used apple cider vinegar to prep bare metal surfaces and as a very light rust converter.
"Hokey religions and ancient weapons are no match for a good blaster at your side kid." |
Owner
Trade: Sandblasting
Rewards Points: 60
I use for rust protection after blasting phosphoric acid (solv in destyl water) great thing but only for couple weeks.
As long as u meaning blasthold-expoxy primer. Im not familiar with the name and could be misleading... |
Sponsored Links | |||
Advertisement |
Rewards Points: 60
Hold Tight 102 is pricey. I was talking with a guy he was saying they use product called "tank safe" I think it was. Says it was a lot cheaper in cost. Guess they use it for water treatment with some fire trucks on tanks that are metal.
Trade: Coatings consultant and Inspector
Rewards Points: 1,334
Pricey is really not valid. Either you want your steel to rust or not. Have you looked at hold blast from Chlor*Rid?
NACE Certified Coatings Inspector Level III #7953 SSPC Protective Coatings Specialist #2014-529-139 [email protected] 205-717-0292 |
Rewards Points: 60
If you had two products tho that offer the same results for rust protection and one was twice the cost or even more it wold make the most sense to me to go with the cheaper one. I totally agree on the fact of getting what you pay for and if it's something you need or is required to have you can't skimp on it if you want to have a good name for yourself.
I've just always used what worked best and as far as cost, as long as it worked, it was just a job cost that went into my pricing.
Mobile Sandblasting
Trade: SANDBLASTING
Rewards Points: 554
I'm looking into it now. Can it be applied with a pump sprayer? Im just looking for something simple and quick. I'll
Look into both. Thanks, I just hate when someone is late to pick something up, that little flash rust looks bad. And I would like to offer it as a selling point. |
It can be, but it works best when added to your blast water. It will last for three to four days as long as it stays dry. Gets rained on and it will rust back as with any of the other products will.
#10 | |
Todd
Trade: media blasting
Rewards Points: 762
Re: Anyone Ever Made There Own Hold Tight/Blast Hold?Quote:
Once again I am not basing this on anything other than what the rep told me from a his mouth to my ears at the last trade show I attended. Note** this most likely was Chlor-rid and not specifically Hold Tight...
www.blastserv.com |
Blastserv, your thinking about Chlor*Rid. This is Hold Blast by Chlor*Rid. Used in the blast water or can be applied after blast either way. Chlor*Rid itself will not stop rust though. Just removes the salts from the surface. Once applied the surface would have to reblasted again per spec. Corrosion would then be very slow to come back. But the product I was referring to was Hold Blast from the makers of Chlor*Rid.
Rewards Points: 126
Easy solution just blast at 4000 psi hahaha
I'd like to see pictures of that!
Rewards Points: 130
I've used both Hold Tite and Hold Blast from Chlor-rid. My preference is Hold Blast. I use a Geo-Blaster and have a 400 Gal. tank plus the geo tank. I'll fill the large tank with approx 200 gal. and put in 1 gal. of Hold Blast and blast most of the day with no problems and no flash rust. Hold Tite with the same 200 gal., 1 gal. mix will rust almost immediately. With Hold Tite, (102) I believe it's 102, I must use a mixture of at least 50 to 1. or almost 4 gal. of hold tite. I now keep 2 extra 5's on hand of Hold Blast. and guess what!!! Hold Blast is cheaper.....
The Following User Says Thank You to Bob Moore For This Useful Post: |
painter213 (03-21-2015)
sodablaster dude
Trade: sodablasting
Rewards Points: 89
Bob, Hold Tight is suggested to use at least 1:100 with water.
How much they asking for Hold Blast? |
http://www.chlor-rid.com/holdblast/holdblastData.pdf
http://www.chlor-rid.com/productInfo/hbbrochure.pdf Here's the data sheet. It depends on what your doing as far as how to dilute. Cleaner water, less dilution.
sodablaster dude
Trade: sodablasting
Rewards Points: 89
what are you doing to get cleaner water? or you just using tap water?
#18 |
I myself don't do anything with the water except test it with a test kit from Chlor*Rid to see what the chloride content is. The higher the chloride content, then the faster the steel will flash rust.
#19 |
Trade: Media Blasting/Surface Prep
Rewards Points: 2
Buy your rust inhibitor in 55 gallon drums to reduce costs. If your buying Hold Tight in gal. or 5 gal. your paying a premium.
#20 |
Rewards Points: 130
Hold Blast in 5's from Chlor-Rid runs around $175. del/No. Nev. Hold Tite from Sherwin Williams runs $220
Advertisement |
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Home Made Electrolysis Machine(Picture Heavy) | shakey0818 | Tools & Equipment | 1 | 03-03-2014 11:36 PM |
Basic carpentry tool kit! my tool kit is included. | CJ21 | Carpentry | 25 | 01-01-2014 10:16 PM |
Just seen a review i made in festool catalog | BCConstruction | General Discussion | 14 | 03-24-2013 03:57 PM |
Fasteners for composite decking | onmywayup | Decks & Fencing | 4 | 10-21-2012 01:22 PM |
Vents to hold down membrane??? | tekwrytr | Roofing | 9 | 05-27-2009 07:44 AM |
Go to Page... |
