Metal Railing Refinish - Specialty Coatings - Contractor Talk
Old 09-22-2019, 07:50 PM   #1
Not a people person
Chris Doom's Avatar
Trade: Remodel/landscaping/irrigation
Rewards Points: 295
I have a black aluminum railing, outdoors that the original finish has worn off of. I seem to remember a high end black brush on paint I saw a painting guy using on wrought iron years ago, I think it was some specialty acrylic paint that was gloss and not cheap. Any ideas of what this might be?
Chris Doom is offline
Old 09-22-2019, 08:21 PM   #2
avenge's Avatar
Rewards Points: 250
Re: Metal Railing Refinish
There's all sorts of acrylic paints for metal. I wouldn't use acrylic without knowing what the existing finish is.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
hdavis (09-22-2019)
Old 09-22-2019, 08:27 PM   #3
Not a people person
Chris Doom's Avatar
Rewards Points: 295
It's a long outdoor railing so I doubt it's a baked-on product finish. Probably a spray on latex finish if I had to guess. I know I could go with a spray-on like BBQ or Rustoleum but I've seen other more durable products out there.
Old 09-22-2019, 09:25 PM   #4
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
S W has a couple of products DTM and another product the name escapes me at this time but it's what I use for pool cages, I spray it most exterior metal work is powder coated
Still "Shakin" the tree boss
sunkist is offline
Old 09-22-2019, 09:58 PM   #5
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 962
I’ve not had any problems painting bare aluminum with acrylic latex however most paint manufacturers recommend an etching primer.
Make sure the existing finish will be compatible with a latex paint , if it’s not it will peel .
Test it by applying some latex paint in an inconspicuous spot , allow to dry thoroughly, and see if it sticks . Or see if denatured alcohol will remove or soften the existing finish
As for brands , any high quality paint will work
Idothat is offline
Old 09-22-2019, 10:20 PM   #6
hdavis's Avatar
Rewards Points: 1,890
DTMs mostly use an acrylic component, while outdoor exposure and abrasion favors urethane. You wind up using something like this:
9700 System 250 VOC Acrylic Polyester Urethane
There are tons of options out there.
hdavis is online now
Old 09-22-2019, 10:24 PM   #7
hdavis's Avatar
A lot of the long rails at churches around here are powder coated, they can do 20' pieces at least.
