High Build Primer? - Specialty Coatings - Contractor Talk
High Build Primer?
Old 12-25-2015, 11:52 PM   #1
18delta's Avatar
Trade: electrical & carpentry
Rewards Points: 24
High Build Primer?
Wondering if someone could help me out with a question... What are suitable interior applications/uses for high-build primer?
Have a situation with fresh paint that peeled off a wall, buddy of mine suggested using a high build primer to correct the difference in thickness between the paint that peeled and the paint that adhered as opposed to skim coating..
I've never used a high build primer and I'm not sure if it would work in this situation. I'd appreciate any advice/info. Thanks!!
18delta is offline
Old 12-26-2015, 12:02 AM   #2
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 294
Re: High Build Primer?
The old self level primer ! No! It won't solve the worlds problems .
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
Old 12-26-2015, 12:06 AM   #3
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
There's tuff-hide but that's prob not gonna work. Just skim the Low spots with some green bucket mud and feather it into the paint after priming.
www.bcconstructionllc.com
BCConstruction is offline
Old 12-26-2015, 12:26 AM   #4
18delta's Avatar
Rewards Points: 24
So, primer first. Then skim coat? Or skim, prime everything, then topcoat?
18delta is offline
Old 12-26-2015, 01:49 AM   #5
avenge's Avatar
Rewards Points: 250
This has already been covered in your other post. High build primer will not fix your issue. You're looking for a shortcut... there isn't one.
avenge is offline
Old 12-26-2015, 09:02 AM   #6
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,477
Prime area that peeled > Skim > Sand > Prime again.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
BCConstruction (12-26-2015), Big Shoe (12-28-2015)
Old 12-28-2015, 05:41 AM   #7
Big Shoe's Avatar
Rewards Points: 2,108
Sorry, I couldn't help it.
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
Nick33 (01-02-2016)
Old 05-31-2016, 07:40 PM   #8
mbrooks78's Avatar
We do those type of fixes all day at work. If you want some thing quick and clean. Prime over the peeled areas using a quick dry primer (go past the damaged area), skim with 5 min mud. Within 20-30 min, you can wet sand it with nothing more than a wet rag and be dust free Once dry; prime and paint.
mbrooks78 is offline
The Following User Says Thank You to mbrooks78 For This Useful Post:
Metro M & L (05-31-2016)
DUPLEX BUILD - FALL 2001 - Frankfort, IN ~ LOOKING BACK 12 YEARS WHEN I FIRST STARTED CCCo. Construction Picture Post 5 06-20-2013 06:18 PM
should my family help build my home in Hawai'i...? woorki General Discussion 4 01-09-2012 07:01 AM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 08:39 PM
Sherwin Williams high build primer jakester Painting & Finish Work 8 11-24-2007 08:29 PM
