Garage Floor Coatings - Specialty Coatings - Contractor Talk
Old 04-07-2018, 10:00 AM   #1
Joasis's Avatar
Rewards Points: 1,794
Anyone had any good experience with the "Rust Oleum" style of acrylic garage floor coatings? Or know of an industrial grade coating system? I want to do the color with the chips. This is for my garage, 30 x 55....so lots of floor.
Built this home 7 years ago, and just now getting to this...the "cobler's kids have no shoes"....
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Insulated Concrete Homes / ICF's
My Facebook Page
Joasis is offline
Old 04-07-2018, 11:36 AM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Re: Garage Floor Coatings
Expert on floor coverings I am not, but experience with crappy floor paint I am. Car tires are super hard on floor paints. Every auto shop I have worked at that has tried painting the floors has had peel up from car tires. Buy the best industrial paint you can! No one wants to shut the shop down for more than a 3 day weekend.
Grind it/ball bearing whatever to take the top off, acid wash it, let it dry, paint it, then don't put anything on it for days. I wouldn't consider parking rubber on it for weeks without putting something between.
Peter_C is offline
Old 04-07-2018, 01:52 PM   #3
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,278
The Rustoleum stuff doesn't hold up or last very long. I've used it.
Fishindude is offline
The Following 2 Users Say Thank You to Fishindude For This Useful Post:
Bull Trout (04-07-2018), Joasis (04-09-2018)
Old 04-07-2018, 02:55 PM   #4
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
https://www.musclegloss.com/
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
Joasis (04-09-2018)
Old 04-07-2018, 04:56 PM   #5
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,962
Do NOT recommend it. The Rust Oleum coating will not hold up to car tires and the warm tires will pull it up.
I do quite a few epoxy floors, last one i done was a 3500 sq ft auto dealership service dept.
I highly recommend you grind the sealer off the existing concrete with a diamond concrete grinder and open it up. To see if your concrete is ready for coating pour some water on it and make sure it soaks in right away, if it beads up it is not ready, keep grinding.
I highly recommend you look at the Armorseal line of epoxy floor coatings sold by Sherwin Williams, they are excellent. There are solvent based, recommended for vehicles, and water based for foot traffic.
If you are going to add color chips in the second coat and the floor will be driven on then the chips will need a coat of sealer so tires don't pull them up. Rexthane is best sealer for the solvent based coatings. Seal off your house and make sure no ignition sources. Nasty stuff but very good.
Once finished consider the floor will be slippery when it gets wet, about like a smooth troweled concrete, no one can suggest to me how to add slip resistance without it making the floor looking like [email protected], so be careful if you go that route.
All your effort is in the prep.
Another option are polymer floors, (all chips with clear finish) that's is all i know about them. Good luck.
Ohio painter is offline
The Following 2 Users Say Thank You to Ohio painter For This Useful Post:
Joasis (04-09-2018), Peter_C (04-07-2018)
Old 04-08-2018, 11:45 AM   #6
txgencon's Avatar
Rewards Points: 468
If you need a quick turnaround, look at polyaspartics (A type of two part polyurethane.) Supposedly, you can park a vehicle on it in 48 hours. I waited a week.
A long time ago, I bought some of this stuff at a salvage place west of Ft. Worth. Supposedly, it was some Desert Storm surplus. It has held up remarkably well and didn't react with a new set of tires on my one ton cutaway a couple of weeks after application. It came only in a desert tan color.
I only wish I had taken a torch to the fiber reinforcement in the concrete. But they again, it might have been took slick had I done that.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
The Following User Says Thank You to txgencon For This Useful Post:
Joasis (04-10-2018)
Old 04-09-2018, 09:42 AM   #7
Joasis's Avatar
There is a commercial grade I saw being applied in a military hangar...and it looked awesome. But I have yet to find anything comparable.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
My Facebook Page
Joasis is offline
Ballpark cost for garage addition? Moze Construction 7 01-10-2015 03:21 PM
Garage conversion thoughts MarkJames Remodeling 6 02-24-2013 09:17 AM
Garage Floor Epoxy We Fix Houses Painting & Finish Work 9 12-31-2012 11:37 AM
Fire Rating of garage walls, exterior siding Richard_N_S General Discussion 9 12-12-2012 09:58 PM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
