Bar Floor Coatings? - Specialty Coatings - Contractor Talk
Bar Floor Coatings?
Old 12-30-2013, 06:05 PM   #1
rservices's Avatar
Rewards Points: 380
Bar Floor Coatings?
I've been asked to coat a bar floor with some epoxy type material.
I have seen a lot of these type of coatings fail in restaurants because of the chemicals they use, my guess alcohol being spilled on it would also have a problems.
Does anyone have any suggestions?
I told them I would rather tile the floor than put down a product that has such a high chance of failing.
rservices is offline
Old 12-31-2013, 04:42 PM   #2
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Re: Bar Floor Coatings?
Buy the REAL DEAL of epoxy coating and you will be fine. Buy a gallon or two from a Big Box and it WILL fail.
Ultimate Wisdom---------
MALCO.New.York is offline
The Following User Says Thank You to MALCO.New.York For This Useful Post:
asevereid (12-31-2013)
Old 12-31-2013, 05:26 PM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
That's right. Or real urethanes, or MMA. They're made to survive food manufacturing, chemical plants, airplane fuel, etc., so a little booze won't do a thing. Surface prep and humidity matter a lot,and materials costs might be $5/square foot, or more for small areas, which turns off someone who has in mind that you're going to mop on some garage floor paint overnight and they'll be slinging beers the next day. MMA if you want a quick turn-around.
I can't pretend to have a long track record with this - I have only one MMA project under my belt, and a couple more in the pipeline. I did a lot of research, though, and have been looking in every restaurant kitchen possible, to see what's on the floor. It appears to me that these coatings are taking over commercial and institutional kitchens - no more quarry tile.
Not that you asked, but the way to sell these is on durability. If it's installed right, they won't be paying some guy $500 to scrape the paint and crud off the bar floor every few months, and repaint with another coating that will fail. Cleanable as anything.
What with the quartz and other color additives, some of these are very attractive, too.
- Bob
CarpenterSFO is offline
Old 12-31-2013, 09:01 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
My friends veterinary hospital has a seamless epoxy floor system which is sanitary and super easy to clean. Wouldn't want it in bar though,...his seems on the softer side though and I remember banging it up pretty bad one day I was working in the kennel area and I dropped something,... left some nasty gouges I did
I'm sure there are other epoxies which would suit the bill, but I would agree, a hard porcelain or stone floor would be nice.
The Hard Rock Cafe in AC uses a slate floor and epoxy grout - that floor has held up quite well through the years and it's taking quite a licking.
Our local WAWA convenient stores use terrazzo, by far the most durable IMO.
supersealconstruction.com
superseal is offline
Old 12-31-2013, 09:22 PM   #5
There are lots of good terrazzo finishes in the resin floors. You have to do the full deal with them: primer, body coat, broadcast the terrazzo flake, and top coat.
Resin floors can be soft, but that's more of an option than a requirement. Some are rock hard.
Sorry if I seem like a resin flooring salesman.
Edit: One of the requirements with tile in public spaces is that your cleaning people have to be good. Not every bar's overnight cleaning crew will be as meticulous as the folks at HR Cafe might be.
- Bob
Old 01-16-2014, 07:28 AM   #6
Supahflid's Avatar
Trade: Commercial Waterproofing, Masonry Restoration
Rewards Points: 254
If impact resistance is required, the way to accomplish that with decorative aggregate is to thicken the system; in lieu of the standard 50-60ish mils, I think most mfg's would require at least double that. Of course, it sounds as though something isn't quite right if the epoxy was damaged as easily as you say.
CarpenterSFO, I presume when you say MMA, you mean PMMA? Which mfg do you use?
Supahflid is offline
Old 06-17-2014, 08:03 AM   #7
http://penncoatinc.com/
PennCoat's Avatar
Trade: Painting / Epoxy Flooring / Polished Concrete
Rewards Points: 706
Epoxies are a cheaper solution, and they perform ok in these situations as long as you have the right top coat. But urethane cements hold up the best. They are abrasion resistant, impervious, and, as far we can tell, preferred by most food inspectors. Dur-A-Flex makes a product called Poly-Crete MD, which we find to be one of the better brands available. And places dealing with food are subject to strict cleaning requirements. So if you're looking to add texture to the top coat, make sure it's still easy to clean with a mop. Here's some more info:
http://dur-a-flex.com/Home/FloorApplications/11
PennCoat is offline
Old 06-17-2014, 03:18 PM   #8
Supahflid's Avatar
Rewards Points: 254
Originally Posted by PennCoat View Post
preferred by most food inspectors. [/url]
Opinion.
