Lowest HERS Index In America - Green Building - Contractor Talk
Old 06-09-2011, 07:00 PM   #1
TheHardWay's Avatar
Trade: Custom Homebuilder
Rewards Points: 25
My latest project just earned a minus 22 HERS index. It also scored a 118 LEED score, the highest new home score ever certified.
TheHardWay is offline
Old 06-09-2011, 08:26 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 678
Re: Lowest HERS Index In America
Hard to believe, with all that glass. What's the story?
Tinstaafl is offline
Old 06-09-2011, 08:58 PM   #3
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
I think i read somewhere that a wall of windows scores higher than a fully insulated, thermally broken wall would.
jkfox624 is offline
Old 06-09-2011, 09:12 PM   #4
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 162
Tin - HERS score is mainly based on Energy Use calculation based on structure, insulation, size, climate, etc.. to go negative that means a lot of solar power (trying to get a house below 50 generally requires solar, or wind)
As for the glass, you can have all you want, you just have to make up for it.
JFox, not sure where you read that, but it maybe possible depending on shading, orientation, SHGC, and what the surrounding walls consist of (i.e. concrete block only)
TheHardWay - very nice job
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Tinstaafl (06-09-2011)
Old 06-09-2011, 09:20 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 678
Exactly. That's why I'm all ears on how it was made up for. And for a bonus, whether the cost of that is actually reclaimable in a reasonable amount of time.
Old 06-09-2011, 09:26 PM   #6
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Nice work HardWay
Those numbers should help your marketing!
-Steve
TimelessQuality is offline
Old 06-10-2011, 06:25 AM   #7
Jeff
jkfox624's Avatar
Rewards Points: 502
Yeah i cant remember where i read that, it was more than likely someone talking out their ass.
jkfox624 is offline
Old 06-10-2011, 07:23 AM   #8
TheHardWay's Avatar
Rewards Points: 25
Thanks for the interest guys.
The design is a direct response to site conditions. The pool photo is the rear of the home and offers a SW exposure. Hence the slope of the roof which is carrying Uni-Solar Flex Lite PV in our perfect orientation.
The view also needed to concentrate to the SW so the home and the pool open up to the hardwood swamp we mitigated during construction.
There is a predominant SW-W breeze that we wanted to capture so I loaded the rear with Centor Accordion Glass walls. This does NOT help my energy issues on paper since even though the the glass is Low-E, insulated, argon filled, and impact resistant it is still only R6 equiv. The SHGC is .19 and the U-factor is .27. In reality there is no heat gain or loss in spite of the western exposure. I designed the roof overhang at 4' after modeling the shade pattern cast from the hardwood swamp. As the afternoon rounds over the eaves it disappears below the trees offering only filtered light. In the winter when leaves have dropped, the broken sun will gently cool the home. Capturing the breezes from the W was only half the battle. I designed the roof as a shed and allowed the breeze to pass through the entire depth of the home and escape out the electronically operated windows on the front of the home at the ceiling height.
Because the environment here is humid, I had to design the interior to hold up. I used polished concrete floors, American Clay walls, paper-less wall board, and cypress everything with exposed duct work. You can see more at www.joshwynneconstruction.com or on www.jetsongreen.com Just look for the Power Haus
The Following User Says Thank You to TheHardWay For This Useful Post:
Tinstaafl (06-10-2011)
Old 12-14-2011, 08:23 PM   #9
P3+'s Avatar
Trade: Builder/Rennovator/Custom Homes
Rewards Points: 150
Hey Hard Way, any insight on the actual energy uses of this home now that it has been in function for several months now? Was this a personal home? Or did you build it for a customer? LEED score of 118, that's gold correct?
Work hard, play harder, die happy!
P3+ is offline
Old 12-15-2011, 12:20 AM   #10
TheHardWay's Avatar
Rewards Points: 25
It is performing as expected for the client. It is the highest scoring LEED Platinum in the world. It won the LEED Outstanding Single Family Project of the Year at GreenBuild in Toronto this past October.
Finding Work In Rural America...HELP MountainBob Business 1 03-11-2011 05:48 PM
So sick of the "Black vs White" in America maleko General Discussion 143 07-29-2009 09:56 PM
Bank Of America Gives In To Republic Windows And Doors Workers Ed the Roofer General Discussion 16 12-12-2008 08:48 AM
